Alpine CDA-9812RB
torquesport
Lets Torque Diesel
Jan 19, 2008
137
Stone, Staffordshire
Got a alpine CDA-9812RB cd player
1#Does this hu need to be connected straight to the battery as ive read else where, as i got it second hand and its got a harness attached?
2#Its fitted and does not turn off with ignition?
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
you'll need to swap the red and yellow bullet connectors round to sort the ignition problem. ie red-yellow and yellow-red as opposed to red-red yellow-yellow.
the headunit should jsut plug straight into the standard wiring as far as i know. My alpine does :)
Carr20vt
952
South Wales
The 9812 is a powerful beast (4x60w) IIRC had many many yrs ago and for this reason Alpine say to power it straight from the battery. It can be run off the oem wiring just battery will go dead quick smart if you have it flat out without the engine running.
At the wiring there is a permanent supply or one powered by the ignition (Accessory switch) to allow it to turn off with the ignition.
andreww
216
Cornwall and Cheltenham
I've been struggling with this issue for 6months now, every time I take the key out the HU forgets all my settings. It's very annoying as the connectors won't come out so I can't swap the Red and the Yellow cables. If anyone has any tips or ticks that would be great.
(My HU plugs direct into the car).
torquesport
Lets Torque Diesel
Jan 19, 2008
137
cut the red and yellow wires and swap them around ive just done it and now turns off with ignition
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
My HU turns off when I remove the key from the ignition, it just forgets things like what track I was playing etc.
Thats because it dont have a perminent live, it only has the switched live. You need both. Thats why you need red to yellow and yellow to red. One of them is a switched live and the other is the perminent live for the memory.
andreww
216
I have proven that with my old pioneer HU, that would forget not only what track I was on but also the audio settings (I had 2 cars at the time to test it in). My Blaupunkt remembers audio settings at least.
torquesport
Lets Torque Diesel
Jan 19, 2008
137
So the yellow that meant to go directly to the battery needs to be switched with the yellow? does that mean i need to take the red directly to the battery instead?
