riffy
Hi, My alternator has given up the ghost....great timing as I now need that on top of 2 new tyres and a cambelt!
My question is: I have the 120A output unit, could I fit the 90A version? I've spoken to parts and they think any one of the 70/90/120A versions could have been fitted to my car.
GSF list the 90A at £115+vat which is much cheaper than Seat. I'm not running any massive ICE or power hungry items :)
120A does sound like overkill for your Leon, my Passat has a 120A jobbie, but has to power heated seats and the coolant heater on top of all the other gubbins...as you won't have those I should think you'd be fine with a 90A.
IIRC my Ibiza was 90A.
Thanks, thats what I was hoping...Seems to have fixed itself at the moment :confused: but I'm sure it will return!
Started car and the battery light stayed on. I popped the bonnet and it was making a nasty grinding noise. Could describe it as a worn bearing noise or similar.
Got home, left it a while, started again and it was fine :confused:
I'm sure it can't just fix itself...or can it ;)
A lot of the alternators fitted to TDIs have one-way clutches in the drive pulley.
Perhaps it didn't engage properly and once stopped/started again it was OK :shrug: (bit like a cheap ratchet drive :) )
Hey that sounds just like it....thanks for the info. It hasn't done it since:)
