jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
also not sure if im panicin but in 6th when coming on and off the throttle while holding the gear stick
i can feel a slight knock / rocking type movement on the gear stick
only in 6th though
mark i also forgot that bike stand .. i will have it so tell him not to throw it out :)
Happen if your labouring the engine? What speed we talking about here?
Also you should be in 5th doing 30-40 mph, you will kill your clutch.
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
yes i know i know tut tut ,, not in the habit of doing it was curious :confused: of seeing what the boost was at minimum etc and if i could drive without being on boost all the time ,
normally dont drive hard below 2000rpm , etc
looking back to when i first bought the car , the clutch started riding when i was booting from Go
but since reading loads of threads here , i realised the torque was too high for std clutches , so addapted my driving style
and nearly 3 years later and nearly 35,000 miles more shes still driving strong ( in that department :blink: )
amm thinking when i drive to cornwall in april , should i disconnect the maf and see what mpg i get , :happy: does driving it disconnected create problems , appart from no boost
Andrewcupra TDI
Apr 30, 2008
3,282
yes have the free version , but i have been using a a freinds one from his work /garage which is the genuine one ,
with maf disconnected , the car seems pretty responsive/smooth during acceleration , but wont go above 60mph , once connected back up u know the turbo works
have full tanked it to see what i can achieve fuel wise , , so far ist early 30's and miles til empty suggests about 350 miles
Andrewcupra TDI
Apr 30, 2008
3,282
a well this weekend im off to pwllheli (north wales ) and off in car not bike so will see the miles i get
jobs done tonight off the checklist
speaker finally fitted
rear number plate off , duct tape cleaned off plate , trim and bumper (been stuck on since wston beach race last year )
stuck back on with sticky pads & lots of them :)
checked oil & coolant ready
also checked under car for damage as i scrapped the floor yesterday :(
just needs to be emptied of junk, washed , hoovered, sun strip fitted & filled up with taxed upon taxed fuel and go
Andrewcupra TDI
Apr 30, 2008
3,282
nope :(
turns out you cant buy gaskets for the outer side of the pump , only the inner part (kidney & figure of 8 shaped gaskets , i need the one where mark has posted
also need time to research where the relay is for the glow plug harness , as that is where i need to check next
