right, wasnt boosting to what it should so i reset the ecu and throttle body and it starting missing. found it to be the maf after testing all the coils to find they were all fine. so i replaced the maf (genuine bosch one) and it played ball for a while but now i'm bakc down to 5psi peak. so i tried re-setting the ecu again and it boosted up to around 8-9 peak as it should and now its back down to 5psi peak
am i right in thinking the n75 is probably the other the other culprit to my lack of boost? all vac pipes are new and checked they are connected properly, the forge TIP is fitted as it should be and secured properly. plugs are new and have been checked and they are fine.
any input guys? i dont have vag-com and run a mac so getting vag com to work would be a pain in the ass! anyone near sheffield with vag com i would welcome your asisstance should it be possible for you to lend a hand
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
