Fitted my coilovers today. I also bought some adjustable droplinks because I was planning on going down about 40mm
My adjustable droplinks are longer than the standard plastic ones....I extended them about 4-5mm and fitted them as I was under the impression I wanted to push the ARB up from the driveshaft? However on testdrive it rubbed like a bitch!
I adjusted them a further 1" but the further I extended them the more they rubbed on the drive shaft?
Looking at the set up I need shorter than standard droplinks as when the ARB is pulled down lower the curve of the ARB sits nicely over the driveshaft and is nowhere near touching......in fact the standard droplinks are better for me than the uprated ones.
Have I bought the wrong adjustable droplinks? I'm thinking I hould have bought Shorter adjustable ones and not longer?
What have you lot done?
I managed to get some pics that I'll add in a min
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
