Yes they add more camber. I also got some SuperPro bushes for the control arm that increase caster.Camber adjusters?
Sent from my SM-N770F using Tapatalk
I was going to get them but there very expensiveI just bought the superpro alloy arms which have both.
Do you think I will need extra fuel, its a full track day.
I'm going to get brakes, hopefully today or tomorrow.We usually try and find a Shell V power nr the track and hit it during the lunch break.
We add octane booster to that too. Or you can take a can but we usually are low by lunch if we haven’t filled up locally on arrival.
Some tracks do fuel on site but it’s not v power and can be more expensive.
Have you done brake pads?
Mate ran standard pads on his 300 with me at Brands and they held up pretty well but I’d recommend an upgrade and decent racing fluid too.
Badger5 Custom Map + TIP,
I've heard that octane boosters aren't that good, but not sure myself.
I was wondering whether I should take a Jerry can so I can have V Power with me.
******TRACK DAY*******
While I’m on,
3 of us are doing
Snetterton 300
On the 7th of November
Price is low £129
Me in my mk1 LCR, a buddy in a
300 ST and a very cool normally aspirated Honda CRX vetch from back in the day. Not the fastest out there but we hold our own.
Love to have some more SEATs there.
Won't make it. 8hr Round trip
Those Honda VTECs are rev happy. for a NA car - they are quick. of course Turbos are an unfair advantage - when comparing apples with apples!
What camber you running?I just bought the superpro alloy arms which have both.
What is static and dynamically?-1 degree static - upto 2.5degree dynamically
Makes total sense. I got 2.2 camber static (i think) so how much would that be dynamically?Static camber is the amount of camber angle the vehicle has at a rest, and is what gets measured when you get an alignment.
Dynamic camber is the amount of camber angle generated as the car goes around corners, when the wheels are turned.
Hope that makes sense
