Sprogpole
360
Leicester
There have been lots of threads about Hesitation on part throttle 3-4k RPM, but none with a successful outcome.
Mine has just started doing it.
Every time in any gear when on half throttle the power goes at 3k rpm and then comes back at 4k.
There is no sound change or strange noises. MAF and Boost stays constant. But it seems to hold back the power through that rev range. Also I can still hear the turbo working at the same rate as above and below those rpm.
Car has Revo stage 1, but otherwise standard.
So far I’ve changed MAF, OEM DV, Plugs, Cam cover and VVT Gasket, oil+filter, air filter, fuel filter, PCV puck and PCV valve, dipstick tube, and the usual split pipes.
Any other suggestion on what to log with VCDS or parts to replace / check out?
Forgot to add – when cold, it can be quite jerky at low RPM.
Also when cold I am getting a fluttering noise that disappears when it’s warmed up. It’s the same noise I got when the vacuum hose popped of the DV.
Good post, you've changed quite a comprehensive list of related parts. I changed most of the PCV parts too to try and resolve. My BAM engined car (stock map) does a similar sort of thing - though I am convinced that switching the OEM DV with Forge 007P did help. I think the rubber diaphragm of the OEM part can't decide whether to seal open or shut and kinda flaps about, perhaps?? Did you stick with OEM DV?
Other suspects might include the N75 but this is unlikely, I think.
Alex
OK, just changed the coil packs, still doing it :(
There really is loads of threads about this on all the vag group forums, but not one solution.
Hi bud im exactly the same. I have read all the posts related to this as im getting the hesitation around the 2k mark. Feels like someone has tapped the brakes or its being starved of fuel then it dumps ??
I have changed 4 coil packs, plugs, N75 and checked for vac leaks to no avail...
Would really love an answer !!
I did read it could be the 1 way valve in the pcv system, its really cheap but a pig to change !!
Dont think its that tricky to change mate, you seen the pcv removal guide?
Yes i have mate to fit a catch can, im about as useful with tools as an underwater hairdryer lol
I can do basic stuff, but dont have half the equipment needed to do it !!
I can program the **** out of stuff tho:D
I've changed the PCV valve and the puck, It was easy as pie tbh, just take the two 5mm allen bolts out the tray that holds all the vacuum stuff in front of the mani, unclip the 2 electric connections and 1 10mm nut holding the SAI pipe bracket.
Fold the tray over to the right. That'll give you plenty of room to do it.
Shame it didn't sort this problem out!!
Ah ok :) this maybe tommorows task !!!
Ive had the exact same problem with my old leon cupra and my current one, buy some carb cleaner, remove the pipe off the side of the throttle body, spray it in, give it a good clean (be gentle) and re-attatch, solved the issue on both my leons. No more jerkiness, touch wood.
For the sake of £3 on cleaner its worth it imo as it gets gunked up over time.
Hi mate thanks, was thinking about doin that. I'm sure tho if I remove the TB and Clean when u re attach u need to do an adaptation with vcds.
I'll have a wee dig around the forum, cheers
Already done that once including a TB reset. Didn't change anything. I will give it another try tomorrow morning though.
If that does not solve it, I'm going to have another smoke test. I will also look at getting the fuel pressure tested.
Let me know how you get on !!
I have just discovered a hole in the breather pipe that comes from the pcv valve to the upper breather y shaped pipe. Not happy bout the price but got it and will fit Sunday.
I'm really hoping this will solve it !!
How's your car doing now?
I've found a boost leak at the join between the metal turbo outlet pipe and the rubber pipe that goes to the pancake.
I'm fixing it on Sunday, so I'll let you know if that was to root of this evil [:@]
Well, after taking the charge pipe off, the pipe that I thought had a hole didn't. It was the heat shield that I could feel by sticking my hand down there :rofl:
Anyway, I have a test for anybody having this problem.
Get on the power in any gear. When above or below the RPM range that you get the hesitation, left foot brake quite hard while keeping your right foot on the gas.
This give me exactly the same hesitation that happens all the time without braking.
I'm going to change the brake pedal switch one evening this week, so I'll keep you updated
Any updates on fixing this issue ???
I'm loosing sleep because if it lolol.
If ain't weren't for the hesitation I would absolutely love my car !! Well tbh I still kinda do lol
Particularly for mapped cars could it simply be the car gets to the required speed as set by your foot and then cuts the boost/opens dv otherwise speed would still climb. Its the abrupt change in boost we feel.
In Sprogs example of accerate/brake together the ecu will cut the revs, so it kinda figures its doing something similar when it feels hesitant.
All guess work ... ive been around this issue throughout ownership and have given up on it.
This is a log of Part throttle. Maybe sombody can spot somthing around 3k RPM?
Code:
	Idle speed	Coolant Temp	Oxygen Sensor	Adj for Basic	Idle speed	Engine load	Inj. period	Air mass in	Lambda Factor	Lambda Factor
TIME	700-820 rpm	80-110 C	-0.2	1x111111	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s
STAMP	 /min	°C	%		 /min	%	 ms	 g/s
31.38	880	90	0	11110111	840	14.3	2.04	2.67	1.991	0.797
32.29	920	90	3.9	11101111	1280	18.8	2.04	3.47	0.891	0.797
33.19	1280	90	-2.3	11101111	1280	14.3	1.7	3.08	0.75	1
34.1	1200	90	0	11110111	1120	12.8	1.7	3	0.984	1
35	1000	90	2.3	11111111	1000	14.3	1.7	2.89	1.187	1
35.91	960	90	7.8	11101111	960	36.8	5.1	9.11	1.055	1
36.81	1000	90	-3.9	11101011	1000	58.6	6.12	12.56	0.883	1
37.72	1080	90	3.1	11101011	1120	69.9	7.48	16.42	1.055	1
38.62	1240	90	7.8	11101011	1280	80.5	8.84	21.5	1.008	1
39.53	1440	90	15.6	11101011	1520	85.7	9.52	25.83	1	1
40.43	1680	91	17.2	11101011	1760	94	10.2	32.72	0.984	1
41.34	1960	90	17.2	11101011	2080	112.8	12.24	48	0.984	1
42.24	2320	90	18	11101001	2480	143.6	15.3	73.31	0.992	1
43.15	2760	90	18	11101001	2920	160.9	19.38	89.44	0.984	1
44.05	3200	90	6.3	11100001	3360	164.7	21.42	110	0.805	0.75
44.96	3640	91	6.3	11100001	3760	159.4	22.44	105.53	0.774	0.672
45.86	4040	91	6.3	11100001	4160	142.9	18.7	105.64	0.75	0.665
46.77	4400	91	6.3	11100001	4480	123.3	15.3	100.5	0.75	0.719
47.68	4720	91	8.6	11100001	4800	118.8	14.96	104.81	0.797	0.75
48.58	5000	90	12.5	11100001	5120	112	14.62	110.58	0.805	0.758
49.49	5320	91	19.5	11101001	5440	112	14.62	116.97	0.805	0.797
50.4	5560	91	7.8	11100001	5280	9.8	1.36	10.31	0.805	0.797
51.29	4360	90	0	11110001	3920	12.8	0	7.69	0.844	0.813
52.2	4120	90	0	11110001	4120	12	0	8.67	1.991	1.047
53.1	4040	90	0	11100001	4080	44.4	5.78	38.33	1.991	1.047
54.01	4080	90	7.8	11101001	4120	89.5	9.52	71.42	1.023	1
54.93	4240	90	14.8	11101001	4280	126.3	13.26	105.03	0.977	1
55.83	4400	90	19.5	11101001	4360	18.8	1.7	14.17	1	1
56.72	4320	90	10.2	11111001	4280	12	0	9.42	0.945	1
57.63	4120	90	0	11110001	4080	11.3	0	9.08	1.991	1.047
58.53	3880	90	0	11110001	3800	12	0	9.03	1.991	1.047
59.44	3600	90	0	11110001	3520	12	0	8.39	1.991	1.047
60.34	3320	90	0	11110001	3240	12	0	7.64	1.991	1.047
61.25	3040	90	0	11110001	2920	13.5	0	7.64	1.991	1.047
62.15	2720	90	0	11110001	2600	13.5	0	6.81	1.991	1.047
63.06	2080	90	0	11110101	1720	14.3	0	4.89	1.991	1.047
63.96	1920	90	0	11110111	2360	12	0	6	1.991	1.047
64.87	2040	90	0	11110101	1880	13.5	0	4.89	1.991	1.047
65.78	1560	90	0	11110111	1400	12	0	3.39	1.991	1.047
66.68	960	90	0	11110111	960	23.3	2.72	3.17	1.991	1.047
67.58	880	89	0	11110111	840	16.5	2.38	2.83	1.312	0.797
68.49	1200	90	0	11100011	1320	63.9	6.8	18.67	0.844	0.805
69.4	1560	90	5.5	11101011	1640	69.9	7.48	23.39	1.031	1
70.3	1920	90	14.8	11101011	2080	85.7	9.52	35.92	1.008	1
71.21	2360	90	15.6	11100001	2160	15.8	1.7	10.92	0.992	1
72.11	1480	89	0	11110111	1320	21.8	4.08	9.17	0.992	1.047
73.02	1280	90	0	11100011	1280	75.2	7.82	20.44	0.891	1
73.92	1360	90	9.4	11101011	1400	83.5	8.84	23.64	1.062	1
74.83	1480	90	15.6	11101011	1560	89.5	9.86	28.11	1	1
75.73	1680	90	17.2	11101011	1720	95.5	10.2	33.06	0.992	1
76.64	1840	90	16.4	11101011	1920	105.3	11.22	40.5	0.984	1
77.54	2040	90	17.2	11101001	2120	124.8	13.26	53.56	0.992	1
78.45	2280	90	17.2	11101001	2360	147.4	15.3	69.75	0.992	1
79.35	2560	90	17.2	11101001	2640	165.4	21.42	80.89	1	1
80.26	2880	90	15.6	11101001	2960	160.9	19.72	90.11	0.883	0.797
81.16	3120	90	12.5	11100001	3240	163.9	21.08	101.14	0.821	0.805
82.07	3440	90	17.2	11100001	3520	165.4	21.42	113.94	0.789	0.782
82.97	3720	90	17.2	11100001	3800	161.7	21.42	120.97	0.789	0.774
83.88	3960	90	17.2	11100001	4080	161.7	22.78	126.17	0.766	0.75
84.78	4240	90	17.2	11100001	4320	161.7	23.12	133.67	0.75	0.727
85.7	4440	91	17.2	11100001	4480	114.3	15.3	94.44	0.75	0.711
86.6	4600	91	15.6	11110001	4320	10.5	1.36	11.03	0.836	0.836
87.5	3480	91	0	11110001	3080	12.8	0	6.78	0.86	1.047
88.4	3080	91	0	11100001	2960	63.2	6.8	39.72	1.991	1.047
89.31	2960	91	8.6	11101001	2960	67.7	7.14	37.89	1.023	1
90.22	2960	92	15.6	11101001	2960	67.7	7.48	39.44	1	1
91.12	2960	92	15.6	11101001	3000	68.4	7.48	38.86	0.984	1
92.02	3000	92	15.6	11101001	3000	61.7	6.8	34.39	0.992	1
92.93	2960	92	8.6	11110001	2960	12	1.36	6.81	0.984	1
93.83	2920	92	0	11110101	2920	12.8	0	6.83	1	1
94.74	2880	92	0	11110101	2840	12	0	6.81	1.991	1.047
95.64	2800	92	0	11110001	2800	12.8	0	6.94	1.991	1.047
96.55	2760	92	0	11110001	2680	13.5	0	7.28	1.991	1.047
97.45	2560	92	0	11110101	2480	13.5	0	6.67	1.991	1.047
98.36	2360	92	0	11110101	2320	14.3	0	6.42	1.991	1.047
99.27	2240	92	0	11110101	2160	14.3	0	5.97	1.991	1.047
100.17	2080	92	0	11110101	2040	13.5	0	5.53	1.991	1.047
101.08	1920	92	0	11110111	1840	12.8	0	4.75	1.991	1.047
101.98	1280	92	0	11110111	1200	15.8	2.04	3.36	1.991	1.047
102.88	1040	92	0	11111111	920	14.3	2.04	2.81	1.148	0.797
103.78	800	91	3.1	11111111	760	15.8	2.38	2.58	0.821	0.797
104.7	1760	91	-1.6	11111111	2200	12.8	1.7	5.61	0.774	1
105.6	2000	91	0	11110101	1920	12.8	0	4.83	1.008	1.047
106.51	1880	91	0.8	11101011	1920	24.1	2.72	9.11	1.991	0.797
107.41	1920	91	0	11101011	1880	30.1	3.06	11.06	0.953	1
108.32	1880	91	1.6	11101111	1680	15	1.7	3.97	1.023	1
109.22	1440	91	3.9	11100011	1480	48.9	5.44	14.72	1.086	1
110.13	1520	91	0	11101011	1560	69.9	7.14	22.47	1.023	1
111.03	1640	90	7.8	11101011	1680	72.9	7.82	24.25	1.008	1
111.94	1760	90	12.5	11101011	1800	71.4	7.48	24	0.992	1
112.84	1880	90	10.9	11101011	1920	70.7	7.48	24.36	0.977	1
113.75	2000	91	1.6	11101001	2040	45.9	4.42	16.25	0.945	1
114.65	2040	91	0.8	11101001	2040	24.8	2.38	8.19	1.008	1
115.56	2040	90	-1.6	11101101	2040	18.8	2.04	7.06	0.969	1
116.47	2040	91	-3.1	11101101	2040	18.8	2.04	6.97	1.008	1
117.37	2000	91	-5.5	11101101	2040	63.2	7.48	30.22	1.016	1
118.28	2080	90	9.4	11101001	2160	106	11.22	46.81	1.023	1
119.18	2280	90	14.8	11101001	2360	118.8	12.58	53.86	1.016	1
120.08	2480	90	18	11101001	2600	118	12.24	59.39	0.992	1
120.99	2680	90	18.8	11101001	2760	115.8	12.24	61.92	0.992	1
121.89	2880	90	18	11101001	2920	114.3	12.92	64.25	1	1
122.8	3040	90	17.2	11101001	3120	114.3	14.28	67.61	0.906	0.875
123.7	3200	91	10.2	11100001	3280	115.8	14.96	74.06	0.813	0.805
124.61	3400	91	11.7	11100001	3440	115	14.96	74.97	0.782	0.75
125.51	3560	91	11.7	11100001	3600	113.5	14.62	78.22	0.774	0.743
126.43	3720	91	11.7	11100001	3760	112.8	14.96	82.44	0.797	0.758
127.32	3880	91	11.7	11100001	3920	112	14.96	84.67	0.766	0.743
128.23	3920	92	11.7	11110101	3960	10.5	1.36	10.53	0.758	0.735
129.13	3800	92	4.7	11111001	3680	12	0	8.03	1.047	0.992
130.04	3440	92	0	11110001	3320	11.3	0	7.36	1.991	1.047
130.94	3160	92	0	11110001	3120	12	0	7.44	1.991	1.047
131.85	3040	91	0	11110001	2960	13.5	0	8	1.991	1.047
132.76	2880	92	0	11110001	2840	12.8	0	7.28	1.991	1.047
133.66	2800	92	0	11110001	2760	13.5	0	7.28	1.991	1.047
134.57	2720	91	0	11110101	2680	13.5	0	7.31	1.991	1.047
135.47	2720	92	3.1	11100001	2800	115.8	11.9	71.33	0.844	0.836
136.38	2960	91	16.4	11101001	3040	166.9	17.68	95.53	1.039	1
137.28	3240	91	19.5	11101001	3360	169.9	18.02	108.86	1.008	1
138.19	3560	90	19.5	11101001	3680	167.7	21.08	118.56	0.992	1
139.09	3840	91	11.7	11100001	3920	163.2	21.42	126.97	0.906	0.758
140.01	4040	91	11.7	11100001	3960	14.3	1.36	8.33	0.75	0.696
140.9	3880	91	-2.3	11111001	3760	12	0	8.03	0.938	1
141.81	3480	91	0	11110001	3320	11.3	0	7.17	1.991	1.047
142.71	3000	90	0	11110101	2880	12.8	0	7.25	1.991	1.047
143.62	2600	91	0	11110101	2480	13.5	0	6.5	1.991	1.047
144.52	2240	91	0	11110101	2120	13.5	0	5.92	1.991	1.047
145.43	1880	91	0	11110111	1800	13.5	0	4.72	1.991	1.047
146.33	1600	92	0	11110111	1400	12	0	3.5	1.991	1.047
147.24	1360	91	0	11110111	1640	12	1.7	4.25	1.991	0.797
148.14	1640	91	4.7	11101111	1600	21.8	3.06	6.72	0.875	0.797
149.05	1600	91	-3.1	11101111	1560	15	1.7	4.17	0.828	1
149.95	1520	92	5.5	11111111	1520	12.8	1.7	4	1.016	1
150.86	1480	91	7	11101111	1480	16.5	2.04	5	1	1
151.76	1480	92	0.8	11101111	1480	24.8	2.72	7.64	0.961	1
152.67	1480	92	-2.3	11101011	1480	28.6	3.4	10.11	0.992	1
153.57	1520	92	-3.1	11101011	1520	32.3	3.4	9.97	1	1
154.48	1560	92	0	11101011	1560	36.1	4.08	11.42	1.016	1
155.38	1600	92	0	11101011	1600	37.6	4.08	11.92	0.992	1
156.29	1640	92	2.3	11101011	1640	38.3	4.08	12.39	0.984	1
157.19	1680	92	6.3	11101011	1720	42.1	4.42	14.17	0.992	1
158.1	1760	92	5.5	11101011	1800	42.9	4.76	14.78	1	1
159	1840	92	4.7	11101011	1840	51.9	5.78	20.19	1.008	1
159.91	1960	92	4.7	11100011	2000	97	10.54	41.81	1.039	1
160.81	2200	92	11.7	11101001	2360	127.8	13.26	60.75	1.008	1
161.72	2600	92	11.7	11101001	2720	139.8	13.6	67.69	0.984	1
162.62	2960	92	8.6	11101001	3080	125.6	14.96	66.56	0.992	0.938
163.53	3280	92	0.8	11100001	3400	125.6	15.64	77.42	0.789	0.719
164.45	3600	92	0.8	11100001	3680	118.8	14.96	83.08	0.75	0.696
165.34	3880	92	0.8	11100001	3960	105.3	12.92	81.06	0.789	0.719
166.24	4120	92	11.7	11101001	4200	88.7	10.88	71.22	0.836	0.797
167.16	4360	92	16.4	11101001	4440	85.7	9.52	72.58	0.914	0.922
168.06	4600	92	16.4	11101001	4680	87.2	9.52	78.25	0.945	0.945
168.97	4840	92	17.2	11101001	4920	86.5	9.52	80.58	0.953	0.953
169.86	5040	92	14.8	11110001	4720	10.5	1.36	13.17	0.953	0.953
170.77	3880	92	0	11110001	3480	12.8	0	7.81	1	1.047
171.68	2560	92	0	11110101	2560	12.8	0	5.97	1.991	1.047
172.59	2520	92	0	11110101	2520	12.8	0	6.31	1.991	1.047
173.49	2480	92	0	11100101	2480	75.9	8.16	41.56	1.991	1.047
174.39	2520	92	6.3	11100001	2560	131.6	13.6	71.14	1.07	1
175.3	2640	92	17.2	11101001	2680	166.2	17.68	87.06	1.016	1
176.2	2760	92	18	11101001	2800	161.7	17.34	89	0.992	1
177.11	2880	92	18	11101001	2920	160.2	20.4	90.28	0.899	0.844
178.01	3000	92	17.2	11101001	3040	162.4	20.4	94.47	0.797	0.813
178.92	3160	92	17.2	11101001	3200	164.7	21.42	101.22	0.813	0.813
179.82	3280	92	6.3	11100001	3320	166.2	21.08	107.61	0.789	0.797
180.73	3360	92	15.6	11100001	3400	168.4	21.76	107.92	0.805	0.782
181.63	3400	93	0	11110101	3360	10.5	1.36	10.56	0.766	0.774
182.54	3200	93	0	11110101	3080	12	0	6.33	1.055	1
183.44	2840	93	0	11110101	2720	12	0	6.31	1.991	1.047
184.35	2440	93	0	11110101	2280	12.8	0	5.92	1.991	1.047
185.24	2040	93	0	11110101	1920	12.8	0	4.89	1.991	1.047
186.16	1680	93	0	11110111	1600	12.8	0	3.94	1.991	1.047
187.06	1200	93	0	11110111	1120	13.5	2.04	3.31	1.991	1
187.97	2320	93	3.9	11111101	2200	12.8	0	5.5	0.953	0.797
188.87	2120	93	0	11110101	2080	13.5	2.04	5.86	1.991	1.047
189.78	2080	93	1.6	11101001	2040	28.6	3.4	12.33	0.922	0.797
190.68	2080	93	-3.9	11101001	2080	32.3	3.4	13.06	0.945	1
191.59	2160	93	-1.6	11101001	2200	46.6	5.44	23.17	0.992	1
192.49	2280	93	4.7	11100001	2360	95.5	9.86	47.83	1.016	1
193.4	2560	93	15.6	11101001	2680	101.5	10.54	52.44	1.031	1
194.3	2840	93	17.2	11101001	2880	100.8	10.54	56.11	1	1
195.21	3000	93	17.2	11101001	3080	98.5	10.54	59.03	1.008	1
196.11	3360	93	15.6	11101001	3440	131.6	13.6	86.89	0.953	1
197.02	3680	93	-2.3	11100001	3760	120.3	15.64	85.81	0.953	0.961
197.93	3960	93	3.9	11100001	4040	116.5	15.64	87.33	0.774	0.711
198.83	4240	93	3.9	11100001	4320	107.5	14.28	90.06	0.75	0.696
199.73	4200	93	1.6	11110101	3800	11.3	0	7.64	0.789	0.782
200.64	3320	93	0	11100101	3240	11.3	1.7	6.83	1.991	1.047
201.54	2600	93	0	11100101	2640	15	1.7	8.22	0.797	0.805
202.45	2640	93	0	11100001	2640	78.2	8.5	47.56	0.984	1
203.36	2720	93	7	11100001	2760	146.6	15.3	85.86	1.039	1
204.26	2880	93	18	11101001	2960	161.7	20.4	91.67	1.031	1
205.17	3080	93	17.2	11101001	3120	163.2	20.74	98.11	0.805	0.813
206.07	3240	93	17.2	11101001	3320	167.7	21.76	105.92	0.797	0.813
206.98	3440	93	12.5	11100001	3520	169.2	21.76	115.03	0.813	0.797
207.88	3640	93	16.4	11100001	3720	166.2	22.1	117.14	0.789	0.774
208.79	3800	93	16.4	11100001	3840	165.4	25.16	109.81	0.758	0.758
209.69	3800	93	0	11110101	3840	11.3	1.36	13.89	0.75	0.649
210.6	3640	93	0	11110001	3480	12	0	7.61	1	1
211.5	3240	93	0	11110001	3120	11.3	0	6.94	1.991	1.047
212.41	2880	93	0	11110001	2760	12.8	0	6.97	1.991	1.047
213.31	2560	93	0	11110101	2520	13.5	0	6.69	1.991	1.047
214.22	2440	93	0	11110101	2400	13.5	0	6.14	1.991	1.047
215.12	2320	93	0	11110101	2320	13.5	0	6	1.991	1.047
216.03	2280	93	0	11110101	2240	13.5	0	5.61	1.991	1.047
216.93	2240	93	0	11110101	2240	13.5	0	5.81	1.991	1.047
217.84	2200	93	0	11110101	2200	13.5	0	5.83	1.991	1.047
218.74	2160	93	0	11110101	2160	13.5	0	5.67	1.991	1.047
219.65	2120	93	0	11110101	2120	13.5	0	5.53	1.991	1.047
220.55	2080	93	0	11110101	2080	13.5	0	5.53	1.991	1.047
221.46	2040	93	0	11110101	2040	13.5	0	5.36	1.991	1.047
222.36	1960	93	0	11110111	1880	13.5	0	5.08	1.991	1.047
223.27	1760	93	0	11110111	1680	12.8	0	4.31	1.991	1.047
224.17	1560	93	0	11110111	1480	12	0	3.64	1.991	1.047
225.08	1400	93	0	11110111	1200	12	1.36	3.03	1.991	1.047
225.97	1000	93	0	11110111	920	16.5	2.38	3.11	1.991	0.797
226.89	1640	93	3.1	11111111	1760	12.8	2.04	4.56	0.93	0.797
227.79	1720	93	0	11110111	1680	12	0	4	0.766	1.047
228.7	1640	93	0	11110111	1600	12.8	0	4.19	1.991	1.047
229.59	1560	93	0	11110111	1560	12	0	3.67	1.991	1.047
230.51	1480	93	0	11110111	1400	12	0	3.39	1.991	1.047
231.41	1080	92	0	11110111	1000	15.8	2.04	3.19	1.991	1.047
232.32	880	92	0	11110111	840	15	2.04	2.72	1.913	0.797
233.22	760	92	4.7	11111111	760	15	2.38	2.44	0.899	0.797
