Not long got a leon 1.8T, it needs work to get it back on the road so slowly ticking off the list. Plan is to ideally get it to 270bhp-300bhp. I know being an AUQ this will need a fair bit of upgrades.
From what I gather I need:
Fmic
Cupra r injectors
Cupra r fpr (4 bar)
Cupra r fuel pump
Cupra r MAF
Oversized TIP
Hybrid turbo or ko4
Sports cat
Bigger exhaust and manifold
Obviously I know brakes and ARB/suspension will be required too, but I know these I can fit at any stage before a remap.
My question is, how much of the engine upgrades can be done before remapping?
It gets tricky with what upgrades you can put in without a map and still have the car run ok.
What can go on without a remap and still run ok
FMIC
3" turbo back exhaust and sports cat (maybe you get an engine light)
Turbo can go on but then you cant go WOT, only easy driving on the way to the tuner.
Fuel pump can go on.
TIP can go on and also font forget a good free flowing filter.
Here is where it gets tricky.
Hypothetically you could install the MAF and Injectors and it should run okay because you're scaling up both at the same time. Bigger MAF would cause the car to run lean normally, but by increasing injector size you can compensate. But only for a short time.
How I would do it is this.
Do you FMIC and Exhaust when you want and even a upgraded filter, you can also do fuel pump anytime but I think it's not necessary to upgrade for your power goals.
Then when you're ready and you have your tune appointment set.
Install the turbo (give yourself a few days advance)
When installing the turbo also put in the oversized tip to match the turbo of your choice, and if you want a bigger manifold go for it but it's not necessary. But since the turbo is coming off anyways then so is the manifold.
Start the car and see if it runs ok
Then install the MAF and Injectors
If it runs like **** swap back to old maf and injectors.
Drive calmly to your tuners
shop and install your FPR and if necessary injectors and MAF.
This is just my opinion and should not be taken like the bible. It is not my fault when something goes wrong, anytime you mess with fuel or air delivery with a car there is risk of failure.
