Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
any update on this from 2009![]()
facelift available yet ?
So i buy this kvw100 and is it a plug and play job or do i have to do more stuff?
Ive got a 05 cupra.
I got my key remote operated windows going up and down for...the grand total of £7.
Where VDS Pro is better also is that you can revert the car's CCM back to pre windows mod. You need a laptop and a VCDS RS232 serial cable to OBD2 (see ebay) plus the VDS pro software. All easy to get, no?
There is one thing though...you have to be super careful that you use the VDS Pro software correctly...directly changing memory addresses in your CCM MUST be done extremely carefully. Do a search on this forum for VDS Pro for more info.
What memory addresses do i need to change in order to get it working ?
I checkd this.... VCDS RS232 serial cable to OBD2 (see ebay) linky. But it only wrks with xp or windows 2000.
My pc and mums laptop run windows 7. Any suggestions on wich one will work? Also do i need vag com to run the VCDS
This is 'the Czech software'. The app is not in English. I had a look at it but used VDS Pro in the end as I felt it has more control - each to their own. I think you still need the RS232 serial cable for it to work?A free software that it said to be able to activate that function if it's compatible with the car's ccm:
http://www.motordiag.eu/mkm/index.php
