Armitageshanks
143
just fitted some chrome tips(Lidl) to mk4 tdi Ibiza exhaust and noticed a corrosion crack almost the length of the back box. What treatments are out there, if any, which could save the box for a few more years.
Mufflerectomy. Chop off backbox at joint with exhaust, replace with pipe and stick the tips back on. :) Sure, this doesn't mean you're saving the backbox :D but it sounds like it's on the way out. They blow quite spectacularly when that corrosion works right through. ;)
Not on a diesel as water is only in very small quantities as a by product of combustion unlike petrol which yields quite a lot!
Glynn
i've noticed this on my car aswell, but resigned myself to just getting a full miltek system when it blows :(
gutted
When i had a Fiat punto and the box corroded i could buy a back box replacement without having to change the whole exhaust system, im guessing this should be common and the ibiza's no exception. I don't want to spend loads. Anyone got recommendations. I suppose i could cut the box off as said above and piece together a second hand box....err.. thinking about it maybe not.
sorry wrong info given so i've deleted it!!
