Back to Square 1 no idea whats wrong
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
the engine is its herssitating like mad banging and poping its horriable.
dont know taking them out this weekend to see what like now been in a month or so.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
heres the logs from 032 and did 030 too as think thats to do with lambda too aint it?
anyway here they are
Code:
	Group A:	'032				Group B:	'030
		Lambda	Lambda	Bin. Bits	Bin. Bits		Bin. Bits	Bin. Bits	Bin. Bits	Bin. Bits
	TIME					TIME
MARKER	STAMP	%	%			STAMP
	0.76	-1.1	-9.4	        	        	0.38	111	100
	1.56	-1.1	-9.4	        	        	1.16	111	100
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Mine started overfuelling at the weekend, sitting in the 11's at idle, no fault codes.
The most common component to cause this is the coolant temp sensor, i replaced that as i had a spare in my tool box and hey presto its back to normal.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
ah rigth i dont know whats gone on mine done some logs of lambda's dont know if there rigth are not?
Code:
	Group A:	'031				Group B:	'032				Group C:	'033
		Voltage	Voltage	Bin. Bits	Bin. Bits		Lambda	Lambda	Bin. Bits	Bin. Bits		Lambda	Voltage
	TIME					TIME					TIME
MARKER	STAMP	 V	 V			STAMP	%	%			STAMP	%	 V
	0.4	0.805	0.79	        	        	0.8	-1.3	-7.8	        	        	0	7.8	0.79
	1.6	0.725	0.7	        	        	2	-1.3	-7.8	        	        	1.2	0	0.78
	2.8	0.095	0.095	        	        	3.2	-1.3	-7.8	        	        	2.4	5.5	0.09
	4	0.185	0.11	        	        	4.4	-1.3	-7.8	        	        	3.6	11.7	0.595
	5.2	0.64	0.665	        	        	5.6	-1.3	-7.8	        	        	4.8	21.1	0.105
	6.4	0.07	0.08	        	        	6.8	-1.3	-7.8	        	        	6	25	0.11
	7.71	0.075	0.08	        	        	8.09	-1.3	-7.8	        	        	7.2	25	0.07
	8.89	0.05	0.05	        	        	9.31	-1.3	-7.8	        	        	8.49	25	0.045
	10.11	0.045	0.05	        	        	10.51	-1.3	-7.8	        	        	9.71	25	0.045
	11.4	0.05	0.055	        	        	11.8	-1.3	-7.8	        	        	10.91	25	0.05
	12.6	0.065	0.06	        	        	13.1	-1.3	-7	        	        	12.19	25	0.065
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
just had a thought as matt said coolant temp sensor could cause over fuelling recently the temp needle never seems to get to 90 and seems to stay just below that could that be the sensor not reading right and over fuelling it?
Just a thought.
Nov 2, 2004
9,335
South Wales
Forget logging 031 as its narrowband.
Does 032 show -1.3 and -7.8 most of the time?
If it does, go to lemmiwinks, set Secondary Fuel Tweak to 98.4% and set Primary Fuel Tweak to -7.23%. Save your settings.
Once again go back into VAG Com and reset your ECU to zero the fuel trims. Now drive your car around as before and allow adaptation to take place. Check your block 032 values, they should be close to zero, if not repeat the above steps using Lemmwinks to correct them. Once you have your fuel trims under control so they do not exceed the + or -10% range and you are happy with them.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
cool cheers phil will give it a try.
need to get settigns turned back up though as tehre on somet liek HB2 and T2 at mine cause garage messges with them to make it run better they said.
Neel-Cupra
MK2 Leon Cupra 2.0T FSI
Jul 28, 2005
389
can anyone help, the following code keeps coming up:
17535 - Long term fuel trim mult. Bank 1 system too rich
ive checked the boost pipes, no boost leaks, maf reads 192 g/s, lamda maybe? can't work out what it could be [:@]
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
sorry mate dont know on that one. you not had it into a garage yet?
192 is good maf reading only getting like 154 of soemt on mine :(
