BAFFLED :-S Red Oil pressure light flashing bit odd
Jem5120VT
Cuprasufferer
Mar 6, 2016
NW London
Hiya All, New to the forum..
I have read through a number of posts, and it has unerved me, however its not the same issue although problem solution could be the same.
Friday I picked up the car after being in garage since 29th Dec, having a few bits of the usual 51 plate Seat Leon Cupra 20Vt issues sorted.
One thing they did do was change the dipstick tube..It had a full service, filters oil, change ect..so I drove home fairly low revs bit of traffic..no issues, stonked it a few times..nothing out the ordinary although I noticed no loud car engine start, then calms down sounds like a boiling kettle like it did before... I thought for how long it takes usually to settle (4/5mins), maybe something was fixed timing wise..car ran fine, engine sound... later next day..cold temperatures.. ran up sounded like crackling (arking or clicking literally was there and then fine, sounded like air/liquidy escaping from a diaphram of some sort,) after completely fine so thought fine to drive..until 4miles after playing, red oil light, oil pressure lamp started flashing and beeping...I stopped as I know before when I have been low on oil, it has been a red oil lamp steady red.. so I checked the oil fine checked for anything visable that could of come loose or hose ect..nothing..checked under car for any visable leak type pattern.. Nothing..as I was close to home thought drive back as engine was completely normal sounding and feeling....I checked online and I had none of the issues, that it could be that were obvious...could still be sump or pump as they may not of cleaned it on service..but engine fine no drop in revs or power, turbo whoosh as normal..I noticed I changed down n then up..light went off..raced a bit and seemd ok.. went down a hill and slowed and agian flashed and beeped.. so took it steady it stayed on all the way home..I thought sensor issue, however I stuck code reader on and no codes and no oil light, I did notice oil is a bit more but on the max mark on dipstick, weary of turning car on, I did and ran up only no real priming turbo noise..no louder engine no rounded engine noisey it did go quieter then clicky, so I decided ad no warning was on and no codes, see what revs do when it reaches temp.. revs maintaind only dropping a tiny smidge, engine sounding bit like alternatory clicking..belts going round.. no oil light, so revd a bit to see if it would make a difference..no light..no engine drama, 15mins left idle probably middle way on the temp gauge..outside air temp supposed 6.5c it stayed like that for a few mins outside temp on car said 6.5 even after sun came out and must of increased the outside air temp. No change on car, I was about to walk away and after 15/17mins..it started to splutter..to sound to stall..I turned car off just incase..no oil light... sorry for essay but thought detail might help diagnosis...before I take it back to garage.. What do you all think?..could be switch but can't be now it wobbles..I wouldn't if thought they would service without checking coil packs and sump n pump cleans.. Help..
Jem
Sent from my GT-I9505 using Tapatalk
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
Hi mate, well the clicking noise is normal that's ur carbon canister, the oil light flashing will prob be the oil presure, if the cars been sitting maybe the oil pick up pipe is blocked, very common on our engines, you really need to do oil changes regularly, if your light going on and of I think it's the oil presure mate, some others may say different.
Jem5120VT
Cuprasufferer
Mar 6, 2016
NW London
Cheers Big John, I was talking to a mate of mine, he has the same car and I gave him a video of what it sounds like and he seems to think it could be the oil pump. It wouldn't be great if they left other parts dirty after a full service, surely the garage would know the worst effected parts would be strainers and oil pick up pipes, pumps ect..She went in working with no dramas with the engine..I get dash board gremlins thats why I have a code reader, but most of it said down to earth which means ECU gets water inside..along with my door seals I have a big problem with condensation n leaks (I have the stuff jus need dry day and time) but this oil light and pressure is a bit odd. Do you think it could be Oil pump?..Not sure if shes had Cam belt, tensioners and water pump done.. shes done 40000 miles since I've had it..could this effect it?
Jem5120VT
Cuprasufferer
Mar 6, 2016
NW London
Hiya Big john, at the risk of further damage the garage guys came to pick up the car, they were going to tow it but after a discussion and looking over the car, 1 guy said switch and I said about the sump and oil pickup and whether it could be that and he said chances are it wasn't cleaned because its under engine probably not and light hadn't come on but I said about the wobble to stall on idle and they decided to drive it back with tow car behind..that made me feel a bit annoyed as they are prepared to risk further damage or issues with my car..but its in garage..I'll update when I know more, just incase it helps someone else on the forum..:)
