bass getting less
envycordoba
323
bournemouth
hey guys bit baffled im running 2x vibe black air 12" subs and when i turn my stereo up quater way up the bass is really good but when i turn stereo up half way it seems to get less really confused as cant find why this is happening??
envycordoba
323
bournemouth
as i turn the volume up on head unit you can hear that the subs get less punchy than when the volume is say 1/4 up as then its really punchy. seems like its fading off as i turn it up :confused:
Mar 3, 2009
823
Hinckley
ok,what are your settings for gain,frequency etc,wheres your mounting location for your earth?using a dedicated subwoofer pre-out for the headunit?
the more info you give the better
thejoose
Check to make sure you have your wiring right - is your earth good on the amp stuff like that
envycordoba
323
bournemouth
head unit is top of range pionner dvd screen with control box in the boot for all pre outs etc. i have pre outs in sub out which is right. the earth is running from seat belt mount to chasis with all cleaned up for good connection always used that for earthing never had any probs before. as for the gain i'll have to check. all the wiring is fine etc
thejoose
Power caps are useless in all but the top end SQ installs - they can put more of a load on your system -
Jonezyfr
114
whats the bass setting on you headunit like? these will need setting up, stuff like preamp, bass, loud mode etc.
other than that id go for the gain and frequency setting on the amps
envycordoba
323
bournemouth
yeah was all set up perfect just suddenly started doing it. since 1st post bought new amp all is sorted old amp had died and just was not working properly
