nick-barnes07 Feb 1, 2007 1,293 0 gloucester Feb 25, 2007 #1 whats the best spark plugs to get for a cupra r , that has been re mapped with a forge fmic, 3" exhaust from the turbo , and a forge diverter valve .
ArosaRacer Wee man returns in a fL mk2 cupra Aug 28, 2005 2,280 24 46 Bayview, Kent Feb 25, 2007 #2 im using denso IK20's in mine
nick-barnes07 Feb 1, 2007 1,293 0 gloucester Feb 25, 2007 #3 where did u get them from, does any shop sell them
ArosaRacer Wee man returns in a fL mk2 cupra Aug 28, 2005 2,280 24 46 Bayview, Kent Feb 25, 2007 #4 mike at imposs fitted them as the VAG ones were causing a misfire under load, and the tips had melted
Ste Active Member Dec 1, 2006 47 0 Feb 25, 2007 #6 I've always found Opie Oils to be quick and reliable: http://www.opieoils.co.uk/performance_spark_plugs/Default.aspx
Empi5 Your scaring me....... Feb 24, 2005 2,806 0 Staffordshire Feb 25, 2007 #7 or http://www.spark-plugs.co.uk/
cordobabrendy FOOORRREEE! Aug 24, 2001 7,642 1 belfast Feb 25, 2007 #8 ive got a set of ngk iridium plugs 1 temp grade colder than std, running as per my sig below.
neil_f225 Full Member Mar 14, 2005 521 0 Feb 26, 2007 #9 i run standard ngk platinium and appear to be fine... change them every 40k as recommended.
