Hi. that's all what you would hope it would be but you make no mention of what you're doing about "
coding" the new battery to the car? If you fail to do this, although the systems are all working well at present what won't be optimal is the charging characteristics for the new battery. You may or may not know that, modern vehicles with stop/start technology monitor their battery performance very closely - look at the negative terminal on most modern cars and you'll see a wee black electronic "box". This is a battery condition monitor which is feeding info on battery performance to the ECU which controls stuff like charging and whether Stop/Start is enabled. What many don't realize is that it alters the charge characteristics as the battery ages and becomes more internally resistive. If this is not "reset" - ie if the relevant ECU isn't "told" that a new battery is fitted and the battery spec, then it'll continue to charge as it was with the old battery fitted. I've been told that if you don't reset then it can dramatically cut the longevity of the new battery.
Sorry if you already know all this, but you make no mention in your post and it's important others know about this. Of course you need a suitable scanner or whatever to do this - like the
dealer tool or VCDS or other which can do it.
