Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
...When slowing you use more fuel in neutral then if you are in gear slowing.
So if you traffic has stopped ahead, slow early and leave it in gear, try to minimise the time you will be sat still in traffic...
When rolling in gear, the ECU knows to give the engine no fuel to keep turning, as it is using the wheels to drive the crank. When in idle, its providing air and fuel to sit there at idle RPM.
Of course! Thanks.
Ecotek valve. And some of those fuel saver magnets. And maybe another Ecotek valve.
Yeah fit an ecotek and then problem solved... The first time you try and use the brakes they won't work and then you'll write the R off... Then because of a "modification" the insurance wont pay out and you'll be push-biking it to work every day![]()
yep you are right mate, they are designed to be thrashed, when i brought my car i drove it around quite carefully and tbh they really dont like it...give em the beans i say...
for the first time in ages i actually checked my MPG the other day and i saw 31MPG how?.....normally its 24....it is unning 270 BHP so thats brilliant..worst ive ever seen is 19 MPG...
anyways, i turn the aircon button off (bottom left) to save a bit of fuel, along with not coasting in neutral....- i never really knew this till i tried it. i have to travel down a few hills from work, and most of the time the traffic is only moving at say 10 mph, so i wack it in neutral and roll. thinking i must be saving fuel, when in fact im not, i just wack it in 3rd and it is better....i dunno you learn something new everyday dont you..![]()
HonestJohn.co.uk's (the Saturday Telegraph's used-car guru) road test of LC 1.8 T says "the long gearing of 25mph per 1,000 rpm in 6th also gives potential for remarkable 43mpg economy at motorway cruising speeds." What?!
Later in article, he also says it's "always been a pleasure to drive returning up to 34mpg if I took it easy."
Road test in full:
http://www.honestjohn.co.uk/road_tests/index.htm?id=19
I've been getting 42 MPG out of my car quite easily... I have gotten 42 MPG several times out of my 230 BHP LCR...
Road test in full:
Were you on the motorway? What was your cruising speed?
Ta
Probably got the 3 and 4 the wrong way round!
Probably, all you people saying he couldn't have got 43MPG, can't actually drive properly, and use the throttle as an on/off switch.
43MPG is easily attainable in a Cupra if I can get over 40 in an "R".
