tully78
56
I thought it would be interesting to gather everyone's car info for new members like myself to look and ogle at.
I was thinking a list of mods done engine type auq etc and a bhp figure.
Mines a 2004 cupra 180 auq.
Mods- air filter and Coilovers
Lol not much yet...
2005 Cupra R Bam eng, Samco lower intercooler hoses on link pipe only, standard tip, dv, exhaust. St1 269bhp 291lbft torque.
I have 2 lcrs lol
first Red 04 Bam engine 280bhp 297lbft
Ap coilovers
Nuespeed induction kit
Nuespeed Heatsheild
N249 removed
Samco breather hose 13mm & 8mm
Red Top coil packs
Bocsh Super Plus spark plugs
FMDV008 Dump Valve
Forge TIP
Forge Boost pipe - intcooler hose
Forge DV Cold Side- Relocation Kit
Forge polished/De-baffled Hard Boost Pipe
Milltek 3" Down Pipe
Blueflame 3" 100cell racecat
Milltek Cat-Back non-ress system
Golf Mk 5 Coil Pack Wire Harness
New OEM altenator Pully
New OEM injector seals
NewSouth Inlet Mani PowerGasket
Oil Catchcan Set-up
PCV System Removed
Other one Black 04 bam 288bhp 290lbft
Forge fmic and samco hoses
forge 007 dump valve
badger 5 tip
bmc induction
Miltec 3" downpipe plus full system
kw coilovers
double din unit
:D :D
I have 2 lcrs lol
Ap coilovers
Nuespeed Heatsheild
N249 removed
Red Top coil packs
FMDV008 Dump Valve
Forge TIP
Oil Catchcan Set-up
PCV System Removed
badger 5 tip
bmc induction
kw coilovers
double din unit
:D :D
Come on then...which one feels faster lol
Black one feels faster.. but the red one sounds better ;)
Red one for boy racer/show off.. (really nice and loud dump)
Black one for stealth
2003 amk cupra r 300bhp/314lbt
Cr turbo k04 hybrid turbo with ported hotside
Ina ceramic coated high flow manifold
Pipewerx downpipe and decat (3inch)
Custom Powerflow 2.5inch cat back
Badger5 3inch tip
Jetex cold air intake with jabba heatshield
2.0 tfsi coilpacks and adaptors
Short shifter
550cc injectors
Rebuild 2 years ago consisting of, dm forged con rods, new bearings and new piston rings
10mm phenolic insulator gasket
All silicone boost hoses
Cold side dv relocation kit
Forge 007dv with yellow spring
Type b toyo sports fmic (known as the wellycooler)
Aem tru boost controller
Southbend single mass flywheel
Updated organic clutch
Forge de-baffled charge pipe
N249 bypass
Need a BBT 15psi actuator then another map should see 330bhp+
This is my LC180 (Sport to Topsport)
Mod list (most important things)
-SFS Overbore TIP
-N249/N112 delete
-Creations Motorsport Coldside DV kit
-Forge 006 (yellow spring)
-Short Shift
-4 BAR FPR
-QSP 5 BAR Inline fuelpump
-NGK BKR7E spark plugs
-Toyosports FMIC piping + ASH FMIC
-Blox Velocity Stack 3" Airfilter
-42 Draft Designs shift bushings
-JD Engineering Stage 2 chip
-Powerflex dogbone
-BAM Racing Phenolic Intake spacer
-Cobra Sports Stainless Single Oval Resonated
-Toyosports 3" Downpipe
-Magnaflow 200 cells Sportcat
-Pagid 312mm grooved front
-Juratek 232mm grooved back
-EBC Yellowstuff front+back
-Wiechers strut bar front lower
-Whiteline 24mm Adjustable Rear ARB
-JOM strutbar front top
-Powerflex Drop link kit + 23mm ARB set
-Koni Sport Kit (35/35mm)
-New track control arms + SuperPro Polybushes
-OZ Ultraleggera Black 18" + Dunlop Pilot Sport (3) tyres
