O2 Sensor is the Lambda sensor![]()
yeah was a little confusion from my side because in holland we only know this sensor as lambda.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
During my drive home the boost was no higher then 0.5bar (8psi)! No error light, no errors in VAGCOM. I could hear the turbo thanks to the P-flo but boost was minimal. worst drive i had in ages!![]()
Hi, are you still boosting only 8psi? have you piped the n75 valve up correctly? if its wrong then it will only boost on actuator pressure 7-8psi, this was my problem just switched the pipes round and it fixed my boost!
Mine boosts to 8psi too. When I clear the codes I get my 22 psi back. After 10 or so miles it feels sluggish and restricts it to 8. If I leave it another 40 miles it will do the 50 mile fault check. This is when my eml comes on and boost is then restricted to 4 psi.
Yea it should be 8psi all the time no matter what and bring up lambda error codes (Took me 3 months to solve it lol), so i suppose yours is fine, havent a clue what your problem is then maybe faulty ecu?
That's even worse then my boost level. What errors do you see when it is in this mode??
Mine is running to rich. Fuel bank 1 (multi). Have changed maf and checked for boost leaks. Scratching my head as to what the problem is now.
That's the one. No longer says intermittent now tho.
When you check the maf wires have a good look at the connector as i am positive i have read about the plug becoming brittle and the pins get loose in the plastic connector causing a P0103 - 35-10 - - - Intermittent fault
