Bishbash25 Leon Cupra R 225
Bishbash25
47
Portsmouth
Hello all thought i would post some pics of my Cupra just joined the forums but very good read on here so far.
Bishbash25
Bishbash25
47
Portsmouth
After doing alot of reading on this forums from you guys i have decided to skip the induction kit now and just smooth the air box but i noticed some drilled there's what you mean by that random holes around the box?
Also looking to remap and my local JKM do it and was looking at the revo remap also going to add a boost gauge and single pod just not sure where i will run the hose to reach DV anyone have idea i best exit hole to engine bay.
Any suggestions from you guys on mods for the car welcome I have the sum of about £700 free to spend at mo.:)
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Boost gauge should be taken from the Fuel Pressure Regulator not the DV. The boost line can be run through the grommet near the bonnet cable; if you remove your wipers and the scuttle panel you will see it.
My drilled box:
just makes more noise!
