Black badges
Jul 4, 2006
513
Maidstone,Kent
silly question how do you make the badge in the grill black, i wanna do this to my car, done a photoshop of my car and i wanna do this to it and i just wanna know how to make the badges black....
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
I have indeed done this on mine :)
Simple really.... but the preparation is by far the most important bit! Not just before painting, but between each stage of the process too. This is what you need to do....
Remove the standard badge and clean it well.
Sand it down to get a good surface to spray onto. Not too heavy sanding, so use a fine grit paper, but put some effort into this so it's nice and even.
Make sure it's clean and 100% free from dust from sanding.
Give it a few coats of primer
Allow to dry.. leave for at least 24 hours, preferably in an airing cupboard or something similar.
When dry, rub down with some very fine wet and dry sand paper under running water to get a nice, smooth, even surface.
Give it a few good, even coats of paint.
Allow to dry.. leave for at least 24 hours, preferably in an airing cupboard or something similar, just as you did after applying primer.
When dry, rub down with some very fine wet and dry sand paper under running water to get a nice, smooth, even surface. This stage might not be needed though, it depends on the paint used.
Apply a few coats of clear lacquer - this is important as this is your paints protection from the elements and from stone chips.
Allow to dry for at least 24 hours, as per the other steps.
When done, use some rubbing compound to finish things off nicely. Don't sand this stage.
It might look like a lot of work... but each step basically involves a few coats of each type (primer, paint, lacquer) and leaving about 15 mins between each coat, so it's not a lot of work. Then rubbing it down takes 30 mins, tops, so again not much work per stage.
If you can get hold of a spare 'S' badge or entire front grill it saves you having to take yours off the car to spray ;)
One thing you'll find is everybody has their own way of doing things like this, so I'm sure other people have approached spraying things like this differently. This is just my preferred method that's worked well over the years :)
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
thats basically the same steps i followed on my old track 205 wheels :p
Should work perfectly but remember to keep the can quite far away for spraying to avoid drips... Its better to do lots of thin coats every 10 minute or so than make it drip and have to start again!! Trust me i know :cartman:
RobM
Sep 27, 2006
4,982
Southampton
I went for a gloss finish for two reasons...
Firstly, the lacquer provides protection so it lasts longer.
And secondly, I wanted there to be 'something' in that grill as I think it looks empty without anything there, almost as if somebody has stolen your S badge. Going for a gloss finish allows the light to hit it and reflect, so you see something is there and you can see it's the S badge.
RobM
Sep 27, 2006
4,982
Southampton
Definitely not spending that much, it's just something I fancy doing as I think it would look good on a yellow car. Not spending £200+ though, as you can get them new from Germany for a similar price :yes:
Cheers for that though, appreciate the thought :)
ikhlaq206
Its all about the .:R
Jul 25, 2006
347
the black S sign looks stealthy and makes the front look more mean
looks better on black than yellow though
