Black Badges....
Brighton Femme
256
Brighton, Uk
I was thinking.. I might spray my seat badges black, like what alot of black dubbers do... What you reckcon??
Do anywhere sell black ones?? I'm sure there look much better then sprayed!!! Anyone already done this mod? I did do a search but nowt found!!
sara
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
I reckon white guys do it too.
But I would say you'd have to paint them, but bcause the surface is smooth - it'll probably look arse when it flakes off
Brighton Femme
256
Brighton, Uk
I mean black cars! not people! :p Phrased wrong sorry!
I wonder if I could get some made up? I know a plastics place... I might have to pop in.. even if it was just a cover.. if it looks poo I could take them off again!
StuRox
Yup, guilty as charged.
I did my front badge silk black.
To save a lot of messing around with the badge, I just covered my car in a dust sheet, and cut out a hole for the badge and sprayed it on the car.
You just have to wet and dry the badge first, then use grey plastic primer, and then the black to get the best finish.
I used silk black, as thought it went best with the rest of the black trim, but I suppose you can use whatever type of paint you fancy.
Here is a pic of the finished job:
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Well It looked easy and was something I had wanted to do for a while so I'm givig it a go (starting tonight).....decided on a slightly different approach by taking the badge off
Dismantle two pieces above then the centre grill pops out
img.php
Then pulls apart is you are carefull
img.php
Homemade spray booth :cartman: following wet and dry to key area
img.php
Spary primer first coat on
img.php
Will keep you posted how it goes
album link if piccy's no work
http://www.pixum.co.uk/viewalbum/?id=1910037
