That's a month longer than mine have!Mine didn't last long eitherMy new ones have lasted three months so far though!
The eBay seller says there is a year's warranty on them... might dare to test him on that.
Pictures!
Stereo before:
After:
Red Cupra vent switches and chrome air vent surrounds fitted:
hi there. how did you get that cubby hole thing to fit in where the head unit is supposed to be? i tried to put mine like that the other day & it wouldnt fit due to the 2 clip things sticking out of the sides of it at the top. do i have to file these away or something or am i doing something wrong?
thanks.![]()
thanks.![]()
Kidinspace has hit the nail on the head there, I didn't have to do any filing or anything, just turn it upside down. Only thing worth mentioning is by turning it upside down you are left with a few little holes in the tray, so don't go putting pennies in there! Or just get a mat for it.Turn it upside down and it fits in the top space.
Cheers mate. It isn't very clean at the moment due to all the grit on the roads haha! To debadge I just got the hairdryer out and warmed the glue on the letters, then carefully used an old credit card to lift the edges of the letters, then just pulled them off. To remove the glue I used Farecla G10 with an MF cloth, although any mild cutting compound should do the job.sweet car it looks real clean. you have made a good job of debadging itno sticky marks. did you use a polish to remove them ?
Slight update, have now fitted twin reflector headlamps.
Left with a problem though, when I put the main beam on the dipped goes off. If anyone has any ideas on what to do with that then I'm all ears.
No pictures though, the car is absolutely filthy minging right now so I'm rather certain it doesn't want it's picture taken!![]()
Scott never found a fix sadly.Have a look through ScottHmk4's thread, I'm sure if fitted his about this time last year, maybe slightly earlier. He had the same issue, can't remember the fix though.
kidinspace, I noticed you're a fellow Android-ergood taste
you getting anywhere with your headlight problem chris??
