gazjones
im changing my rear disks and pads soon, and also my car is now over 2 years old and got 18k on the clock, so brake fluid change is needed.
ive got a gunsons ezeibleed that i used to do my 312mm conversion. my question is, is this good enough to do a full fulid change on a car? and secondly how would you go about doing it, ie clear system off all fluid first them replace or just flush through with the new stuff? final question i take it you bleed the first caliper that if furthest away from master cylinder then go around working closer to the master cylinder, then go around again checking all air is out of the system?
also does anyone know of a decent dot 4 brake fluid, ive been told rbf 600 is good, how much would you need to do a change, 500ml or a ltr?
sorry for all the questions!!!
gaz
gaz
