Bonnet lifters Help needed please
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Doh often helps, if you paste the link in:
CupraPower
613
Woking, Surrey
I think i know the answer....
There are two bolts on the bonnet. You've probably got it on the wrong one. So it doesn't create the right angle to close it.
You need to undo the top bolt and put it on the other.
Hope that makes sense. Then it will close. ;)
flashbsd
so you've got them on the top hinge bolt, and the bolt 400mm away from the top bolt on the wing?
i just followed the german instructions and got the jist of it, also forbez's photo ;)
The bonnet doesnt go all the way up as expected, but its much better than knocking the stay and waiting for the crash.
flashbsd
i would suggest the same, if its any help, on the box i have: 40006 ona white label.
although i do think they could have found a better looking girlie for the box!
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
Thats the code i got on mine aswell.. really, really dont understand this.. Surly i cant be doing them wrong? i have tried everything..
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
lol still not done?!? shocking!
i cant understand why it wont shut?
as said earlier...most of the kits just have different bolts, the lifters are the same length for most so if the bolts are in its the right kit!
come to pod on the 6th of Nov we can fix em! :lol:
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
Just to wind you up, ive got mine on aswell!! :cartman: :cartman: :cartman: :cartman: :cartman:
Got them on the other way to forbez tho!!?!
:shrug: Fitted better :shrug:
H17OCH​
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
Lol cant believe this, unlucky me or what!!! do you bolts stick out alot? for the lifter to clipp onto it, mayb thats my mine are so diagonal? coz the bolts dont stick out enough on the hinge? i dunno, bloody things lmao
flashbsd
silly question but you did use the washer didnt you? and they are fully threaded in?
i don't quite get how they are'nt working mate lol!
so you cant even get yours to clip in the ends ?
forbez, the rubber bits i had, they were put inside the top of the bonnet to seal the wiring that goes through to the ECU, it needs removing as it fouls on the lifter.
any chance of a close up of your hinge joint?
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
Yeh i did use the washer lol yeh i can get them to clip in, check out my pics at the beginning of the thread, just the bonnet just wont shut,as its hitting the wing bit where the bolts are, well i can get it to shut ( by forcing it) just the bonnet doesnt fit flush..
SWANSWAY CUPRA Dealership
