Make a hole next to that clear pipe but it looks like it already done just find the ends of that clear pipe have u took the lower pa el off inside car
Sent from my C6603 using Tapatalk
Just use the hole already there pal that clear pipe is from a previous boost gauge or pull it out and fit the new pipe all is good
Bonus mate so I would install the gauge end first so that you then have enough under bonnet to route it to the vac pipe woop woop
Haha I no lol well looks like It won't be on today as the pipe I've bought is 2 short so trip back to the shop tomoz :( but least the pipes in now will just join it on the inside ov the car tomorrow.
I wouldn't join it mate get yaself 3 meters of 3mm silicone hose you don't want a leak from a join
I bought 2 meters thinking that would be enough lol but will try it as it's all stripped down now with pipe in place so will just make sure its tight when I join it see how it goes :/
Not a clue mate I took mine from an ignition source in the fuse box on the side of dash that's a black wire bottom right as you look at fuses a 10amp
Yeh found my meter mate just bodging the gauge in on the dash for now as my piller pod won't be here till Tuesday but least it's all in ready just going to tee into the fpr in 10 mins then giv it ago :)
