You wont need a 35psi guage but you will be making 20+psi remapped. I suppose if you map doesnt make 20psi in the first place then you wouldnt need one.
dont know what its running at the minute, hence why i need the gauge
it is remapped though, its on a ARP 98RON Stage 2
loads of other guddies on their too
Has anyone got pics on where these connect to the engine ?
and where you feed the cables through the car to engine??
iv got a amp wired up and the cable runs under the glovebox to the battry, i presume these will run through at a different place to the engine????????
yep the small hose on the top of the DV pointing upwards, you wont have much length on the hosing so you wont be able to take it through the passenger side.
Oil temp sensor, i think there is a post not too old with photos
finally got the boost gauge wired up last night (after it only arrived yesterday), seems to be working fine, the boost goes between 18 & 21psi every time, does that sound right ??
cant get the oil temp wired up though, how on earth do you get your hand down to get the nut off youv got to put it onto ????? is their somewhere else this can go ?????
both gauges look mint by the way - really happy with them
