I've recently bought a Stage 2 Ibiza Cupra with a RR printout at 274.5bhp and 285ft lb. The mod list is as long as my arm including K03S hybrid, Live map, N249/SAI delete with resistors, turbo-back Milltek, TIP, Forge 007P etc.
But anyway, I was wondering what sort of boost levels the car should see at this spec with that amount of power and how it would behave tailing off etc?
Also have a very odd boost fluctuation issue whereby if I load the car up about half way and watch the boost gauge it'll hit 10psi then fall back to 5, then 10, then 5 etc. I've done some vagcom logs if anyone would like to see those.
I genuinely thought it was the N75 valve but today having tried an MBC bypass on the N75 with no change I'm stumped now. Few people have said it could be the actuator?
Need your help 1.8T gurus! I'm pretty clued up on these engines but this one's got me!
