Boot stuck :(
Shock_Xe
Any ideas how i can open me boot on me mk3 cupra?? the lock mechanism still works but wont open from outside, any clues??
Pabs
5,936
Basingstoke
when mine does it on my leon I just have to wait for a while - it eventually opens (usually the following day)
There is a method to hitting the lock when its open but i dont like it.. never seems to work for me.
May 25, 2004
2,691
Newport, South Wales
Mine does this, I have now left the cover off the bootlid so I can open it from the inside! The mech seems to need oiling and is fine for a certain amount of time until it happens again. Pain!
danregs
Leon Cupra 20VT
Oct 26, 2004
427
Exeter
www.bugproject.co.uk
yeh maybe a bit of release oil poured in through the lock barrel from the outside would do it since you can't get to it any other way??
either that or wait til it decides it wants to open one day and then get the panel off the inside of your boot and grease it up good and proper :)
claudefrog
683
At home
www.reallymeansounds.com
pull down seats
remove parcel shelf
unplug the speakers
remove the 4 plastic nuts holding each speaker pod in place and lift off
remove the screw in the boot handle on the inside
remove the 2 screws located behind the little flaps on the inside of the boot lid
grab the boot lid plastic and pull it hard, it will some off
then you can release the boot by pulling the release rod
once opened grease all the moving parts and refit
p.s.. can you tell it happened to me last week
claudefrog
683
At home
danregs said:
:happy:
you cant beat the voice of experience!!!
oh it gets better... my bonnet realease ****ed up the day after, had to do some messing to get that opened... ordered another mechanism for it, but still not arrived.. so i currently have no middle bit of my grill on :whoops:
Shock_Xe
thanks guys, looks like its back seat down then :(
thanks for the replies
