Brake fluid change - how often
wrexham
261
My car is 3 years old with 68k on the clock, never had a brake fluid change, should it be changed now?
mgrays
371
19
Aberdeen
For sure every 2 years.. the brake fluid sucks in water .. it then boils at a lower temperature so your brakes fail soon after a high speed stop.. also the water tends to hang around the seals and so corrode your master cylinder and slave/calipers.
