Brake light fault but not pedal switch...
I have had a brake light problem for the past week. Top light stays on dim but gets bright when peddle is pressed, other two do nothing. Traction control light is on all the time. Vag Com error was
00526 Brake Light Switch (f)
011 Open Circuit
I have since removed and replaced the Peddle switch with no joy. When switch is removed i get EPC light on dash and brake lights stick on. When new one was put in i go back to same problem as above. All fuses have been checked. Im now thinking it must be an earth problem or something?
Any help greatly appreciated.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Worth pointing out you get that open circuit fault if both brake lights bulbs are blown.
