andy1280
9
www.facebook.com
I just noticed a spring light flashing on dash and my back brake lights not working the strip break light is working but main brake lights are not any ideas guys??
Also, change the bulbs, more often than not, there a problem with the bulb, the bulb may still be working but there still can be a problem with it.
Well today I was treated to a "fine" selection of warning lights, initially just the ABS and ESP, but later the engine fault light and EPC - second time with this car - Polo late 2002, asked wife to check brake lights - no lights on! Ah well, maybe six years is all you can expect from the original and the first improved version. Time for a trip to VW and keep the car off the road to avoid getting shunted! Only good bit is that that Polo seemed to miss getting its under dash covers fitted at factory.
I bought the latest "6Q0" variant today, parts guy said "fit with pedal pressed down you need to hear/feel two clicks" - this is the second time I've done this job on this car, so changed switch - no brake lights! Switch plunger seemed to be solid, took switch off, now plunger is free to move again, checked pin1 > pin4 with plunger "out" and plunger "in" both times O/C!! Anyway, took rear clusters off and checked them = okay, had a look at circuit diagram, feed comes from large fuse that also feeds lights etc, other lights okay, refit rear light clusters, refit new switch again with pedal down, brake lights work now?? Now I have read the Leon thread and see that others have had some issues fitting these new switches. I'm just writing this in case it helps someone else when they do this job.
What I failed to clear up was that these newest "6Q0" switches MUST be fitted with the pedal in the upper (rested) position.
