Brake Lights Are Staying ON - HELP!
Mistert
Seat Leon 1.9TDi '54 plate.
I'm having intermittent problems with my brake lights staying on. Think it's the switch under the brake pedal. Thought I'd cured it with a bit of WD40 but it's back!!
HOWEVER - what's worse is that it has drained my battery FLAT. But when I try to charge the battery of course the lights come back on - aggh! So I have removed the bulbs from the left & right rear brake lights - BUT I have an overhead break light at the top of the boot. I don't know how to disconnect this one so that I can charge the battery & then take the car in to my garage.
Any help most appreciated.
Battoussai
531
182
Portugal
You could remove the fuse for the brake lights. Then you can charge the battery. And the brake pedal switch needs to be replaced otherwise you'll be back to the trouble. You aren't driving it like that are you?o_O
Mistert
Good plan! If I can get the battery charged & start the car I'd have to replace the fuse before taking it to the garage to get a new switch fitted! Alternatively get a mobile repair guy to visit.
iammooks
1,822
1,223
Take it to a garage? Why would you do that?
It was one of the first jobs I did on my car and it's nowhere near as difficult as you'd think. A little awkward, but not really worth paying someone else to do.
Mistert
Problem is I'm 72 with a bad back!
Mistert
Can’t you remove the battery to charge it then put it back in ??
Think it may be easier to remove the fuse for the brake lights. So I'm going to give that a go. But thanks anyway.
Rich.T
1,609
932
Im 46 with an ok back. If you are near Bedford, i can fit a new switch for you next Saturday (for free).
Reactions: iammooks
RADIOTWO
516
98
North Derbyshire
i have sentPM
