Brake pads
Deev
331
Croydon, South London
My Leon TDI needs new brake pads all round. My stealer quoted me about 170 quid for the job. I've phoned around and had a few other prices. National Tyres and Autocare quoted me about 135 quid, and a local chain called Wilco Motorsave quoted me a mere 80 quid.
Now obviously I want it done relatively cheaply and as far as I'm aware brake pads are pretty much brake pads (unless you're fitting uprated ones but that's not the issue here). I used to fit them to my old bangers all the time but frankly these days I don't have the time or energy to be injuring myself doing that :D
So has anyone got any advice or horror stories regarding this? Am I as well to go for the cheaper option (Motorsave aren't a huge company but they're quite a big local chain in this region and seem competent enough) or could I be asking for trouble? :think:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
brake pads are not brake pads 'm afraid.
cheapo rubbish can fade when you need em most and fall apart
Deev
331
I've just called Motosave back and they say they fit either Quinton Hazell or Lockheed depending on availability. Both reputable brands are they not...?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Jurid also reputable brand but they scare the bejesus out of me... one stop and they're dead.
you pays ya money and ya takes ya choice at the end of the day.
these are your brakes tho is all i'll say
goodluck
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Fitting front pads is a doddle. Most of what you pay will be labour, so the best way to save money is to do it yourself.
Rears are more difficult, but I think you should look at the rear pads and check that they really do need doing. Rear pads last practically for ever, there is very little braking effort contributed by the rear end as all the weight is at the front when braking.
I do all my own brake servicing, it is one of the last purely mechanical jobs that can still be done with no special tools. Disk pads are easier to change than drum shoes, and the only tool you might need is a generic wind-back tool for the rear caliper pistons. You also get to check the condition of the discs and the flexible hoses, and you know you will take more care than the garage mechanic.
The lowest bidder will be using the lowest cost materials to keep his costs down. If you are happy with that, well and good. I wouldn't be.
Deev
331
Yeah had it only been the fronts I wouldn't have been too fussed as I know they're a piece of the proverbial to fit but the rears are indeed more of a pain. I'm going by what my stealer said re the condition of my brakes though. They did my MoT but warned me that my rears needed changing more or less straight away and the fronts "in the next couple of thousand miles" (and I've already done about 500 since).
What pads would you recommend then? I thought QH were a decent brand? I've used them without problem in the past...
Deev
331
Hmm okay tell me you told me so. I took my car to Motosave after all (it was a budget thing, alright!) and they have already called me to tell me my discs are knackered too, despite my main dealer telling me less than a month ago that my discs were fine and I just needed new pads "in the next couple of thousand miles".
Only goes to show the cheaper places will try to fleece you elsewhere...
Deev
331
Well I've just spoken to the dealer again and they say that at the time they were of the opinion the discs were fine and they aren't likely to have degraded that much in such a short period. They too are of the opinion that Motosave are just trying to upsell.
I've seen the discs myself from through the alloys - there's no scoring in them - there's a bit of a lip at the edges where it has worn over time but I would think this is normal of all discs. They're not brand new, they're just not in need of replacement yet (in my opinion, and indeed that of my dealer!)
si-mate
Jai Ho or Jay Ho?
May 31, 2004
941
Kunt Centryside
In that case ask to see the discs before you agree to them changing them. I'm sure if you search on here you will find out at what depth of groove you need to get them changed.
Then you can say to them that they've got another 2mm (for example) before they need changing.
