KarlB1
326
Aylesbury
Hi guys
Need rear discs and pads on the Leon and front pad as these ones seem to have worn at an angle so going to check the piston too.
Can anybody confirm the sizes of the rear discs on a 2004 Leon Cupra TDI (i'm guessing same as the FR TDi) as europarts seem to list 2 different sizes?
http://www.ebay.co.uk/itm/Seat-Leon...376&pid=100015&prg=1006&rk=1&sd=300714487271&
Does this seem about right? seems quite cheap to me but i've had Mintex on my old MR2 and they seemed alright..
Size on that item is 232mm but europarts do PAgid ones that are 232mm or 256mm?
288mm vented for the front
And 232 solid for the rear!
Complete poop setup!
Fr tdi should of had 312's up front
Reactions: KarlB1
Did this ever get resolved? Im having exact same issue now. Still searching.
Which bit do you mean?
The cars going in to the garage that did the front brakes tomorrow, they're doing the rear discs and pads for a charge and replacing the front pads under parts warranty, I mentioned the front offside inner pad is rattling in the caliper and the guy said they could be the wrong ones, so they're doing them for free.
