Brake warning light :S
brad1
Well yesterday driving to work, this light pinged up on the dash
i thought, weird, the pads are only a month old, so i check them this monring and still pads are like new, checked the plug and all still plugged in together, im confused as to what has happened or causing this :confused:
This happened to anyone else before???
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
wire still in the pads or you fused it together?
id strip the sensor out and check it, could have blown the sensor...
vagcom will confirm this for you
brad1
What part on vagcom do I check, as I'm sure I checked the abs and
other associated brake catergories and nothing came up :confused:
brad1
Well I've been out tonight and the light suddenly decided to turn off, but 10 mins later it pinged back on again :(
Aug 7, 2009
1,395
Manchester U.K
Dodgy connection then, the wear sensor is only a piece of metal what creates a curcuit when it touches the disk, its probaly come out of the pad, my old pads did it but changed them anyways.
BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
Mines just started doing this! Any news?
Just so i understand what im looking for, can anyone confirm that the pad/disc connectiion SHOULD be open circuit (no current), that then makes a contact once the pads wear, making a closed ciruit, and thus tripping the alarm?
Surely tho, if that is the case, when the pads are unplugged, the ECU wont see a fault?
