s20ty c
138
lancaster
:shrug: i am trying to find a filter that will fit on the breather pipe for the secondary air pump, has anyone got a link to a website i can buy it straight of! and how would it fit without cutting it to the filter as it has it has a connection for the air box and i dont want to remove the secondary air pump?
The connection used to plug it into the airbox will need to come off. But if you fit a open cone then you'll be removing the entire airbox anyway...
then just measure the plastic pipe diameter wise, and stick a breather filter one there in the same size...
Like this (see front of bay)
i dont what to do this just yet, thanks tho, i want to no how people have conected the breather fillter with out cuting the pipe so i can put it back to standard easy!
matt@sws just attached a small breather filter to the plastic piece in a recent threat. Infact if you looks at Rev's picture above you can see he has a red filter on the end of his. Just need the correct size filter.
