samborghini
I've recently brought a turbo intake pipe from creation Motorsport for my leon cupra (auq engine code) and have just got round to fitting it. Seems to be good everything fits fine etc but I have a breather pipe left with no where to go. (I think I got the tip for a different engine code by mistake) but I don't really wanna pull it all out and send it back if I don't need to as it isn't the easiest thing to fit (not much space) so was wondering if this would be ok running atmospherically, and weather I'd be loosing any performance/boost etc. Even though I think it pulls slightly better and turbo seems to spool quicker how it should be.
Thanks. :)
Dont leave it open, you wont be happy when it sucks in some dirt and chews up the turbo compressor, these engines are designed to have a recirculating air system so block it off before you drive it again
Ok what would you reccomend trying to plug it with? And would it run fine like that, no loss of power or anything? Cheers.
www.ebay.co.uk/itm/271126865413
You're welcome ;) There are NO adverse effects, listen to Keithslippery
When you say you got a breather pipe spare, is it the corrugated type that runs round to the front lower left of the engine.
It's the pipe that connects to the bottom of the tip, not the one out of the air box if you were thinking it was that? There's definatly no place to put it.
