II've got the same car and I've just replaced the front discs (312mm) and pads with drilled Brembo Xtra discs and Xtra pads. £203 delivered for the whole lot from Autodoc and they're brilliant. Totally smooth and quiet but much more responsive braking. Mine are barely bedded in but when you touch the brakes because some tool in front of you on the motorway pulls out, you feel yourself slide ever so slightly forward on the seat. Oh and they look very cool too!
HIGHLY RECOMMENDED.
HIGHLY RECOMMENDED.
If I was you I'd go Cupra front setup but use the Clubsport S discs.
There are some cupra brakes for sale in the for sale section on here
Cupra full brake upgrade 5F Clubsport S discs - DS2500 pads
Leon Cupra full front brake kit 5F 2 Callipers 2 Carriers 2 Lines Clubsport S discs Ferodo DS2500 pads This was a great upgrade to the standard set up, they are around 1 year old. Plenty of life left on pads and discs. There was a hot spot on the disc when braking at 40mph, I have been...www.seatcupra.net
Should be this
