Bugs inside the headlights
markandcath
Our new alhamba has bugs inside the headlights.
Is there an easy way to get them out and is this normal or failed units.
markandcath
Took to bulb out and taped a thin tube to the vacuum. Sucked them out a treat.
Cheers all.
woodwaaa
My side light access cover has dropped down inside the front wing, how do I retrieve it?
woodwaaa
side light cover retrieval...
I wonder if I take the front wheel off and then partly remove inner plastic wing cover, that I may retrieve the side light cover from there?
TimsBamma
30
Hi Woodwaaa, I should think that removing the arch liner should do it, I had to do so when investigating why my rear water jet didn't work and needed access to the washer bottle.
Good luck:)
