Apr 9, 2022
Hi, my bulb check error suddenly appeared one week ago. I didn't do anything to the lights in my car, not any modification.
The error apperas only when I press on the brake, but there is not any faulty brake light, everything works as it should.
I tried to replace the brake bulbs anyway but the error still consists.
I scanned with my vcds and it says there aren't any errors...
Can someone help me with that?
Tuesday,21,June,2022,21:25:02:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: VSSZZZ6JZCR122048 License Plate:
Mileage: 112420km-69854mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: VSSZZZ6JZCR122048 Mileage: 112420km-69854miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CD HW: 03C 906 024 CD
Component: CGGB MM4HV G 8548
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 62CB1F8FBE4FB89665-515A
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 110224DB216F00B4882524E684D900401300
Shop #: WSC 04941 000 00000
VCID: 000F350797030A8613-8054
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0330
Revision: 00 26 08 Serial number: 0000002364209-
VCID: 24475997E7DBF6A657-8070
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 024120816
Coding: 64882BE888610100002008F06E0B0CC800C0002F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 4581E413CCA1EFAE60-8010
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3110
Serial number: --------------------
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3110
Coding: 020000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA09 H09 0020
Revision: -------- Serial number: 003GX012X2TX
Coding: 003039
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D68D-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB405T11GSI892Z
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB405T11GSID9M9
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6J0 920 803 HW: 6J0 920 803
Component: KOMBI H02 0504
Serial number: 00000000000000
Coding: 110201
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 66C3039F9967C4B689-8032
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 022200
VCID: 70EF65C7A3A31A06E3-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 0504
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0D6AD-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11211
Shop #: WSC 06402
VCID: 2F6DA6BBEA1D45FEBA-807A
End-------------------------(Elapsed Time: 02:08)--------------------------
If you have replaced any of your bulbs with LED then this can cause it. I replaced my reversing light with an LED one and it started showing a build warning and causing the left indicators to speed up (as if one has blown) making me think there was a problem with the indicators rather than the reversing light.
If not it maybe a faulty connection to one of the lights and when the brake light are powered one of the other rear lights are not sending the correct signal or response.
If you can I would disable the bulb checks one at a time and see if it stops after doing these.
Failing bulbs can show a warning light just before they go pop, believe it’s a high resistance that causes that. Change/swop one at a time till it goes away?
