bulb guard in headlights
Mar 8, 2007
831
is it possible to remove this or buy it seperatly?
I want to fit some into my fabia headlights to enable me to fit HIDS
any advice?
Mar 8, 2007
831
ive fitted them but there is a quite a bit of glare.
might be because ive got D2S, should I have D2R bulbs?
thinking a diffuser would help
regards
joel
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
I don't think earlier Ibiza's have a diffuser fitted (I stand to be corrected) so can't see it making any difference.
And cant see the 'S' or 'R' bulbs being too different as my understanding is that is only a reference to the length of the bulb.
Could it be that your headlamps just need realigning?
Take them to a local MOT centre and ask if they'll check them for you.
Regards Guy.
Mar 8, 2007
831
there are some D2R/ H7R bulbs which have "blackouts" along the bulb, reducing glare.
does anyone know about the anti-glare caps?
are they removable?
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
the diffusers are removable
I know cos I bent one whilst fitting my HID's
remove 2 little philips screws for the bulb holder mechanism then the diffuser will hook out
go for the VW polo ones and they have "VW" cut into them
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
There are diffusers on the pre facelift Ibiza headlights and no diffusers on facelift models. So maybe swap them for facelift lights? I have HIDS and fit behind diffuser fine.
