Just searched the net and found its not easy to change between the 2 different fitting types.
See here
http://forums.vwvortex.com/showthread.php?4529083
Looks like you need to fi d which part is leaking ie the pipe or the washers etc.
Shouldn't be too difficult to see where it's coming g from and workout what's needed.
I had the banjo bolt...then i converted to bamboo, I had the fuel lines out when changing the injectors on my car...all i can say is...sooooo much quicker to remove the fuel pump! worth it!:whistle: reminds me I need to check my follower soon!
Keep an eye out for S3 fuel lines, I got mine for 20 quid...which included the Thrust sensor as well..! Bargin!
