Can´t Pass from 5,500rpms!
surfo
Leon Cupra 1.8T GT3071R
Jul 13, 2004
81
www.xmsports.com.mx
Hi, my brothers ibiza´s FR 150hp has a weird problem... nothing shows up on the Vag-Com, and car simply won´t pass 5,500 rpms... after a TBA it does go fully to 7,200rpms but then it falls to 6,500.. (same gear) and later it will do no more than 6,000rpms... and Again later in same gear it won´t go farther than 5,500rpms and stays like that...
Testing was made in 1st, 2nd and 3rd gear several times...
it has everything OEM.
any ideas?
redcupratdi
Offical SCN Pole Dancer
Oct 13, 2005
755
cambridge
any ideas?
not diesel is it :p
no serious note sounds like a dealer visit?
they'll be someone here that knows the answer, i'm just a twit!
Glassjaw
well practiacally he is right in a way, i had the same problem i changed the original AIR BOX FILTER, i removed the entire box , put in a SIMOTA filter i would prefer other brands it was just cheap at the time and it was fine, and still is and the problem was solved.
SWANSWAY CUPRA Dealership
