1981whips
153
any one near buxton with an lc and some knowledge of them as im sure theres more wrong with mine
ive done vag com and keep getting 177705 - pressure drop between turbo and throttle valve (check D.V.!) p1297-35-10---intermittent.
ive checked all the pipes but carnt find ant leaks.
ive got a splitter R on which is only 6months old
turned splitter back to resurculating
and still get same problem
but i have just read that you should not connect a boost gauge to the vacume pipe with these. which i have
what problems does it cause (is this one of them?)
any one got any picks of splitter connected to the FPR?
any help advice welcome as i love this car but getting sick of all the problems
any one been out again today but carnt find any thing would it do this if i had a hole or poor conection to my boost gauge as this is the only place i havent looked as this boost gauge seems to be working properly but meens taking it to bits to look.
i have used this shitty clear tube that came with the gauge and have been told under heat it can split and ive checked it after a run and it feels realy warm squigy
might be worth contacting forge to see if your set up could cause that fault.
have you disconnected the battery since changing back to full recirc?
is the car running ok?
you could block off the boost gauge pipe.. and see if it goes?
D.v Problems
I Know Its Been Asked And Asked But Ive Had A Fault Code Pressure Drop Between Turbo And Throttle Valve Check D.v
Ive Checked All The Pipes For Leaks And Havent Managed To Find Any Holes Or Leeks
Just Put My Old Plastic One On And It Runs Far Better Even The Dump Valve Sound Sound Better But I Have Got A Cia On
Boost Gauge Is Going From -20- 10 Peak
But With The Splitter R Valve On It Goes To -25 - 10 Peak Somtimes Even -30
Have I Set It Up Wrong Ive Had It On Full Recurculation And Semi Atmostheric And Get The Same All The Time
Any Advice Or Help Please Fed Up Of Things Going Wrong
Im Not Sure Where It Was Set Before But Now Ive Took It Of Ive Changed It To 2 Full Turns And Will Try It Again Later See If Theres Any Change
Havent Dis Connected The Battery But Cleared The Faults With Vag Com
Been Out Today And Put The Old Plastic D. V On And It Sounds Better Than The Splitter R
And On My Boost Gauge With The Plastic One I Get -20 - +10 Psi Peak
And With The Splitter It Shows -25 Somtimes -30 - +10 Psi Peak
I Have Emailed Forge But It Was On Saturday So Dont Expect An Answer Until Tommorrow
confused with faults
I Know Theres Been Loads Of Threads On This But Ive Been Reading For Nearly 2 Hours And Not Found The Answer I Want
Ive Got The Fault Code Come Up Saying N249 Malfunctioned
Thats After Ive Had The Pressure Drop Between Turbo And Throttle Valve With My Split-r
So I Swaped Back To The Standard Plastic Shity One And Im Getting The N249 Fault But Seems To Be Running Fine And The Bosch One Seems To Sound Better For Some Reason I Do Have A Cia On Aswell
Question Is Where Is The N249 Valve (any Pics As Im Thick)
What Problems Will I Get With This Failing
And Is There Any Checks Or Solutions For This Problem
And Any One Near Derbyshire Whos Done A N249 By Pass
A reformat for those that find it hard to read:
I know theres been loads of threads on this but ive been reading for nearly 2 hours and not found the answer i want
Ive got the fault code come up saying n249 malfunctioned
Thats after ive had the pressure drop between turbo and throttle valve with my split-r
So i swaped back to the standard plastic shity one and im getting the n249 fault but seems to be running fine and the bosch one seems to sound better for some reason i do have a cia on aswell
Question is where is the n249 valve (any pics as im thick)
What problems will i get with this failing
And is there any checks or solutions for this problem
And any one near derbyshire whos done a n249 by pass
I must need glasses as I find it easyer to read
I know theres been loads of threads on this but ive been reading for nearly 2 hours and not found the answer I want
ive got the fault code come up saying n249 malfunctioned
that’s after I had the pressure drop between turbo and throttle valve with my split -r
so I swaped back to the standard plastic shity one and im getting the n249 fault but seems to be running fine and the bosch one seems to sound better for some reason I do have a CIA on aswell
question is where is the n249 valve (any pics as im thick)
what problems will I get with this failing
and anyone near Derbyshire whos done a n249 by pass
ive looked for splits but noticed there a load of oil or sumit around the fpr if thats leeking would it cause this problem as forge have siad i sould have my boost gauge connected to that and not my vacume pipe (NO CAPITALS)
just realized its not the fpr whats go oilon it (like i said im thick) its the thing under the dump valve and a bit further forward where the vacume pipe goe down whats covered in oil but i thinck that might be of me engine as carnt see any leeks
