Ok so looked it injector today, plugged in and wiring looks ok as far as wires go,
unplugged and put multi meter on the two prongs, read pretty much zero flickering,
took number 2 of and did same with engine running bad, voltage was around 5 volts.
so my problem is feed to my injector?
I've peeled wiring cover back to a point and can't see any breaks or rubbing marks,does anybody have any idea where this injector wire goes?
I was thinking about cutting connector to injector off and testing the 2 wires that go into it to see if it's a fault with connection in clip thing,
if that fails and it says no Fred to wires there then I will need to fit new wire at both ends (which is why I ask where it goes) then tape it to old loom
