Can someone have a mosey over my logs pls!
rudgey
Mk2 Leon TFSI Sport '06
Jul 2, 2008
286
near Midland VW ;)
Hi all,
Was wondering if someone could have a look over my logs pls. Ran out of road before i got to the limiter tho! Car doesn't seem to be having any probs but would just like to know if the maf is ok etc for peace of mind if you know what i mean! First part of the log isn't full throttle just pondering about then i nail it! Car is a mk2 tfsi sport, running a revo stage 1 remap btw!
Code:
STAMP	Engine Speed	Engine Load	Intake Air Mass	Throttle Drive - Angle Sensor 1	Load Status	Intake Air - Temperature	Misfire - Sum Counter	Self-Adaptation - Steps Counter	Boost Pressure - (specified)	Boost Pressure - (actual)
	 /min	 %	 g/s	 %		°C			 mbar	 mbar
456.75	2080	24.8	10.78	8.6	Part Throttle	21	0	4	410	1010
457.65	2080	24.1	10	7.8	Part Throttle	21	0	4	390	1010
458.56	2120	22.6	9.5	7.8	Part Throttle	21	0	4	280	1010
459.47	2160	15.8	6.5	5.9	Part Throttle	21	0	4	300	1000
460.35	2160	16.5	6.94	5.9	Part Throttle	22	0	4	300	1000
461.26	2160	16.5	6.92	5.9	Part Throttle	22	0	4	320	1000
462.16	2200	18	8.33	7.5	Part Throttle	22	0	4	440	1000
463.06	2240	24.1	10.92	8.6	Part Throttle	22	0	4	450	1010
463.95	2280	25.6	11.78	9.4	Part Throttle	21	0	4	450	1020
464.86	2360	24.8	11.5	8.2	Part Throttle	21	0	4	380	1020
465.76	2400	20.3	9.61	7.5	Part Throttle	21	0	4	380	1010
466.67	2440	20.3	9.58	7.8	Part Throttle	21	0	4	380	1010
467.56	2480	20.3	10.17	7.8	Part Throttle	21	0	4	320	1010
468.47	2520	17.3	8.33	6.7	Part Throttle	21	0	4	300	1010
469.37	2520	15.8	7.78	6.3	Part Throttle	22	0	4	300	1010
470.28	2560	15.8	7.5	6.3	Part Throttle	22	0	4	300	1010
471.16	2560	15.8	7.61	7.1	Idle	22	0	4	310	1010
472.07	2520	15.8	9.03	7.1	Overrun 	21	0	4	310	1020
472.97	2480	15.8	8.56	7.1	Overrun 	21	0	4	310	1020
473.88	2400	15	8.28	6.7	Part Throttle	21	0	4	550	1010
474.76	2360	36.1	20.81	14.5	Part Throttle	20	0	4	2110	1450
475.67	2680	121.1	87.31	99.6	Part Throttle	21	0	4	2220	2290
476.57	3280	182.7	131.69	99.6	Part Throttle	20	0	4	2230	2290
477.48	3920	179.7	149.89	99.6	Part Throttle	19	0	4	2190	2160
478.37	4520	175.9	167.81	99.6	Part Throttle	19	0	4	2070	2050
479.27	5080	166.2	179.44	99.6	Part Throttle	19	0	4	1900	1900
480.18	5560	155.6	184.58	99.6	Part Throttle	19	0	4	1780	1830
481.08	6000	148.9	191	98	Part Throttle	21	0	4	1680	1710
481.98	6360	140.6	190.17	96.5	Part Throttle	22	0	4	550	1810
482.87	6520	22.6	13	12.2	Idle	20	0	4	310	1140
483.78	6320	17.3	25.72	14.5	Idle	19	0	4	310	1090
Also, why doesn't it say full throttle? And should my actual boost at idle be circa 1 bar!?!?!?
Thanks!
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Are you actually holding full throttle? If you are it could be your throttle sensor going. I think your log is a bit mucked up anyway, maybe you should read up on the ross tech website on how to do them.
rudgey
Jul 2, 2008
286
near Midland VW ;)
Ok, cheers guys! Yeah i'm holding full throttle. I sorta guessed how to do them anyway. I'll have a look on the ross tech webby, do some more logs, then post em when i've got chance.
Thanks!
