car cuts out when warm
keets
:(:(Hi there ive just bought my first biza 2,0 8v and had my first break down. i set off on holiday yesterday got on to the motoway and a mile down the road the car engine just died. it was a bit heary as there is no hard shoulder on that section of motorway. i waited 5 mins the car started again and i got 200 yards again then it cut out again. i was recoverd by the RAC got home and changed the fuel filter, took it for a quick blast and it did the same again. it seems to be when it gets warm. any got any idea,s please
thanks keets a newbie
keets
Hi there thanks very much for that. ive fitted a new crank sensor last weekend so it must be the coil pack. cheers:
keets
Hi there again just been and bought a new coil pack and its still doing it going to take the week old crank sensor off and take it back to A to Z motor spares and get a new one. ilse keep up dating on my progress. cheers keets
samc
143
before you take it off, when it dies pull the coil lead off at the dizzy end and lie it on the rocker cover, to see if it sparks. could be fuelling related rather than ignition,
keets
Hi there fitted a new filter yesterday that was the frist thing i changed. cheers yours keets.
samc
143
may be faulty fuel pump relay or pump also, worth checking for a spark just to be safe
keets
;) just been to andrew paige and bought a new crank postion sensor and the car seems to be ok it does not cut out just splutters a bit when started up. cheers for that. i would never of thought it could be a part that was only a week old.
samc
143
someone else on here had the same problem with a brand new crank pos sensor, sure they changed lots of other bits before they tried another too. easy enough to change but thats not the point, should get money back for the hassle
