Car is down on power wat could it be
Mitchy
TTRS
Oct 12, 2004
2,310
3rd gear in LCR is approx 85mph
4th gear in LCR is approx 105mph
They should do it in 5th gear on a 6sp and 4th gear on a 5sp for a 1:1 engine/gearbox
Remap you should be peaking at 21-22psi and holding 19-20 and then dropping to around 16-17 in the red
rst_cupra_r
jamie from essex
Jul 23, 2005
470
Braintree, Essex
will have to wait for big boys to vag-com it im goin to get a greens cotton filter universal cone to replace th shitter ram one i should be able to get a universal green cotton cone that fits th rams fittin kit then whack back on the chromed heat shield thing
Mitchy
TTRS
Oct 12, 2004
2,310
It is safe to run without maf for a short period as a test.
It may solve your problem.
Boost gauge is advisable, that way you'll know of any problems straight away!
If the ram air is to blame, your maf will be knackered and you'll need a new 1. Cost about £70 IIRC.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
jamie... jabba isnt quite 3hrs from u! (well shouldnt be)
do as you plan... go to bbt...shaun/chris will be able to see if ur maff if fcuked with vag com and im sure they will be able to use it in conjunction with a sps3 switch to optimise ur car.
dont worry im sure they will sort it !:)
i know its not much help now, but... wen we meet at the essex meet we wil have to go out in eachothers cars to see wat they are like :)
good luck!
james :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
wat u doin next monday?
u goin to the meet in surrey? (the one alex is organising?)
i should be! :)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
There is nothing wrong with a RamAir filter - simple as.
MAF's fail... mounting of the induction kit with insufficient care on vibration isolation is the main cause of peoples problems on ALL induction kits. Why do so many std cars also suffer MAF failures? Crap sensor.
MrsB Lupo continues to work fine on RamAir 18months on.. ZERO MAF problems and very healthy performance.
Green will not flow any more than a RamAir. If mounted the same inside the RamAir housing the MAF may still fail (assuming it is not working properly currently, with no logs or data to confirm/deny yet)
