Noam
182
I get the same judder as a coilpack blown but no missfires or codes or Check Engine light.
I was told it's most likely spark plug failure :confused:
Denso IK22 . 15000 km.
Any suggestions?
How's that??
No codes related to MAF
No limp mode.
Car is fine but when full boost hits it judders like a coilpack gone.
fault codes are not 100% reliable, particularly if its intermitent,
id say all of the above, eg coil, plugs or maf/induction kit are potential issues.
Firstly check all coils are in place ok, then maybe put the airbox back on seeing you have recently put the induction kit on.
regards the maf... you say why would that cause this.. - well given this is used to calculate and apply the correct air/fuel ration it would seem possible that if the maf was reading incorrectly then the mixture may not be correct and at high boost / revs (where there is more demand) this may show as a slight misfire.
Same for the plugs..
You could try running with the maf dissconnected as it will run using slightly safer assumed figures.
Coils would be the favourite usually, but id be checking all of the above.
If you dont have a spare coil its a good time to get one.
you could even change each coil in turn to see if it alters.
Thanks Andy . Thinking of all the above too .
Will pop in the garage tomorrow morning .
Hope it's only a coil as I like my induction sound and a MAF is a lot priceier .
Plugs were changed 15000 km ago to Denso IK22 BTW.
