Car Jumps?Judders when wheel spinning.
lmiller
Boost Junkie!
Aug 9, 2011
527
South East Kent
Hi guys,
Now first of all I would like to stress im not some chavvy boy racer that likes to do a burnout from every junction.
Recently I had a Stage 1 remap on my LCR 225 :D i thought I would give it a blast with the traction control off as it was flashing even in 3rd, well as you can imagine it was spinning up bigtime. The problem is when it starts wheel spinning it feels like my car has turned into pneumatic drill! It Judders really badly.
Does anyone know what causes this and can it be fixed?
J@mes W
Stage 1 Revo'd LCR
Jun 28, 2009
985
Colchester
That's wheel hop, its not very nice. uprated dog bone mount (DBM) will massively reduce it, as will stiffer suspension. THS and powerflex both do DBM's.
THS do engine mounts too, this reduces it further still.
lmiller
Boost Junkie!
Aug 9, 2011
527
South East Kent
Just another quick question, where is the best place to get these DBM's from? Is it just 1 i need and is it easy to fit or gonna cost me a bomb?
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
Yes as above you need a uprated dog bone mount. I have the ths kit but is pretty pricey. You can buy a uprated bush to go in your current mount. Powerflex do them for around £20.
If anyone could put a link up as im on my phone.
sambryant
Mar 26, 2009
4,848
Bristol
Really easy fit. If its done at a garage then it will only take 10 mins. Bit longer if its done at home as you need to be under the car.
5,275
Wolverhampton
In my case one of the mounting bolts sheared, so what should have been a ten minute fit turned out to be a three hour job!!
Definitely try it at home first though, if things come apart easily enough then it is an easy job. You don't even have to support the engine.
jebus
60
Wheel hop is not good, had a puma that did it :( a lot of cars do it, but luckly the dog bone mount mod that can get on the Leon does reduce it a fair bit, seen a few vids on you tube i think showing the difference in engine movment, was impressive.
lmiller
Boost Junkie!
Aug 9, 2011
527
South East Kent
Yes I was suprised when it happened and quite shocked it was that bad... didnt notice it before remap but now with the extra power it really is noticeable
jebus
60
Done it a few times im my cars, non have been powerfull in anyway, did make me laugh though so much noise and drama and sod all else happening
SWANSWAY CUPRA Dealership
